steve lampert Posted on Mar 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
13 feet by 13 feet carpet is how many square foot
Brew Meister
Level 2:
New Friend:
  • Expert 62 Answers
  • Posted on Mar 18, 2015
Brew Meister
Expert
Level 2:
New Friend:
Answers
62
Questions
Helped
19885
Points
200
tace899
Level 2:
Sergeant:
  • Expert 291 Answers
tace899
Expert
Level 2:
Sergeant:
Answers
291
Questions
0
Helped
80163
Points
751
Multiply 13 with 13, that is 169 square feet.
  • larry
    larry Mar 18, 2015
    why do you want sq ft you should be talkin sqare yards for carpet. check this out, you got a 13 by 13 area, simply multiply width times length, 13x13=169.sq ft,NOW if your needing that figure to buy carpet or want the square yard remember they only sale it by 12 or 15 foot wide. your 169 sqft area is divided by 9=18.7 sqyds/but the roll size is 15 wide 4 example you end up paying for 15x12=180sf divided by 9=20 sqyrds of carpeting. 15 by 13 tards
1 Related Answer
danoyachtcap
danoyachtcap
  • 2907 Answers
  • Posted on Mar 14, 2015
SOURCE: what's the square footage of 18 feet by 13 feet
234 sq ft. Hope this is what you need.
He square foot of 11ft 6 inches by 13 ft 2 iches?
break it down to inches then multiply the inches then divide that answer to get back to square feet
11 feet is 132 " + 6" =138"
13 ft is 156"+2" =158"
138 X158 =21804 sq"
1sq" =.006944 sq ft or
1sq ft=144 sq"
21804 divided by 144 = 151.4166 sq ft
Rates,Proportions and Percents
that is one huge bathroom you must have the footage wrong. Divide the $762.50 by the cost of the carpet per square foot to get the cost .
How many square meters in 90,000 linear feet of 41.3" wide material?
First, we need to determine the number of square units in the Imperial system. We can choose to do the calculation in feet or inches.
Let's do it in inches first. There are 12" in a foot, so we multiply 90,000 by 12 to get 1,080,000 linear inches. Multiplying this by 41.3", we get 44,604,000 square inches. We can convert this to square feet by dividing the number of square feet by the square inches in a square foot. Since a square foot is one foot by one foot, or 12 inches by 12 inches, there are 144 square inches in a square foot. Dividing our previous answer by 144 will give us 309,750 square feet.
Converting to square metres. An inch is defined as 2.54 centimetres ("cm"). Thus, there are 2.54cm x 2.54cm in a square inch or 6.4516cm^2 in a square inch.
Using the 44,604,000 square inches we got above, and multiplying this by 6.4516, we get 287,767,166.4 square cm. There are 100 cm in a metre, so there are 100cm x 100cm in a square metre. So there are 10,000 square centimetres in a square metre. I get 28,776.7 square metres.
There are 3.280839895 feet in a metre. So there are 3.280839895 x 3.280839895, or 10.76391042 square feet in a square metre. Taking 309,750 square feet and dividing by the 10.76391042 we get 28,776.7 square metres.
Good luck.
Paul
How many square foot of floor panels do I need to cover a room 12 foot x 6 inches x 13 feet in square eet?
To convert your 2 dimensions to square feet you have to multiply them together.
12.5 x 13 = 162.5 square feet.
You do not give the size of floor panels you want to use
To find out how many panels you neeed, divide 162.5 by the square footage of the panel
eg, 12" x 12" panels are (1x1) 1 square foot so you would need 162.5 of them.
24" x 24" panels are (2x2) 4 square foot so you would need 41panels
2answers
How long is 13 cu feet like how many foot is that
One cubic foot is a cube one foot long, one foot high, and one foot wide. How long is 13 cubic feet is is not answerable because it could be any number of lengths depending on the lengths of the other two dimensions.
2answers
HOW DO I CALCULATE THE SQUARE FOOTAGE NEEDED TO LAY A WOODEN FLOOR?
Hello, width x length,measure the largest portion of the room and if you have a small area like a alcove measure that also then add your totals up. hope this helps
PS I try to convert to feet
Turn 675 squared feet into room dimentions
You can devide it up how you want. 675 squar feet is like having 675 one foot by one foot squars so a room that is 10 foot in one direction and 10 foot in another is 100 square feet so 6 of those would be 600 square feet and say a room that was 7.5 foot by 10 foot would be 75 foot
What is 9600 cubic ft converted to square ft?
Cubic foot is a unit of volume. Square foot is a unit of area. There is no direct conversion between them.
A 9600 cubic foot room with a ten-foot high ceiling is 960 square feet. If the roof is eight feet high, the area is 1200 square feet. If the roof is 12 feet high, the area is 800 square feet.
I want to know the total sq foot of a 16'x14' room the total of a 14'x5' and a total of a13'x13' room Or the total of all 3 together. Thanks
If you have a calculator just turn it on and typ[ what follows.
[X] means you press the multiplication key
[=] means you press the = key
[+] means you press the addition key (plus)
16 [x]14 [=] area of first room.in square feet
14[X]5[=] area of second room.in square feet
13[X] 13= area of third room in square feet
If you want to obtain the total area of all the rooms at one go
16 [x]14 [+] 14[X]5 [+]13[X]13 [=]
k24674
ADMIN Andrew
ADMIN Andrew
