Computers & Internet Logo
A
Anonymous Posted on Feb 27, 2015
Pls teme solution for whats app cant show time zone as india, i changed so many times time in whats app, agian it shows wrong time
Windows 8.1 version, model no: 15-g163nr, i installed bluestack software in my pc
THE HOW TO GURU
Level 2:
Habit-Forming:
  • Expert 46 Answers
  • Posted on Feb 27, 2015
THE HOW TO GURU
Expert
Level 2:
Habit-Forming:
Answers
46
Questions
0
Helped
3999
Points
279
"WhatsApp" it does not thread well with windows, is the purpose for whatsapp to communicate with loved one's via text? & have you gone to http://sourceforge.net/ (link bellow & seen there sandbox emulation programs? Or thought of maybe running ROM using a virtual box type program I heard that's what the cool kids are doing? or how about that bluestacky what'chama'whozitz? Here is why I'm pushing you away from whatsapp, it's had some big setback right from it launching & now the developers are scrambling to get it to play nice with Windows 10! but try this, try uninstall whatsapp then run Cleaner now update your windows system "a widows update" reboot & reinstall! what'cha'mawhozits Thank You Find Create and Publish Open Source software for free
How to change time on my Alexa show 8
Here's how you do it.
  1. Swipe down from the top.
  2. Tap the Settings cog.
  3. Scroll down and choose Device Options.
  4. Tap Date & Time.
  5. Click Time Zone and choose yours.
How to change the time on your Amazon Echo speaker, Show ...
Videos as well
https://www.google.com/search?q=change+time+on+my+Alexa+show+8
During setup an incorrect year and time entered. how do I reset them
Setting the date and time in Windows 10
Note: Windows 10 automatically adjusts your date and time for you and only allows you to adjust the time if you disable this feature. If the wrong date and time is being set, you may need to change your time zone, or if you want to increase or decrease the time for other reasons, follow the steps below.
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen.
Click Adjust date/time.
Make sure your Time zone is set properly if your computer is displaying the wrong time.
To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Setting the date and time in Windows 8
In the lower right-hand corner of the screen, click or tap the Windows Notification Area where you see the date and time.
Select Change date and time settings... in the bottom of the window that appears (shown below).
Time and Date in Windows 8
In the Date and Time window, under the Date and Time tab, click the Change date and time... button.
Make your adjustments and click OK.
Click OK on the main Date and Time window to save the changes.
MacOS
Choose Apple menu > System Preferences, then click Date & Time.
Click Date & Time, then set the date and time automatically or manually.
Automatically: Select “Set date and time automatically,” then choose the network time server for your region.
Manually: Deselect “Set date and time automatically,” click today’s date on the calendar, drag the clock’s hands to show the correct time (or enter the time), then click Save.
Click Time Zone, then set the time zone automatically or manually.
Automatically: Select “Set time zone automatically using current location.”
Manually: Deselect “Set time zone automatically using current location,” click a location on the map, click the Closest City pop-up menu, then choose the city closest to your location.
Click Clock.
Show date and time in menu bar: Select the checkbox to see the date and time in the top-left corner of the menu bar. In “Time options” and “Date options,” set how you want the date and time to appear.
Announce the time: Select the checkbox to hear the time announced, then choose when you want it announced. If you want, you can customize the voice.
How do I correct the time on an Apex Solo 7.85 tablet
Tap on the Settings app and then Date & Time.
Set the time or have it use network provided time.
When i turned on my tabeo the date and time were different, and i dont know how to change it back
Wrong time zone and there should be a menu to change it to what ever you need like a computer.
3helpful
WHATSAPP ACTIVATION VERIFY CODE
my samsung star2 whatsapp is not responding properly and verification code also not sending properly.
2answers
Cd/dvd drive wont show files
i think you have a hardware problem and need to seervice the drive, open it up and dust it out. the cmos battery shld give you 3V if its a desktop. you shld try clearing the memory with the jumper on short, then setting the time agian and see how it goes
56helpful
9answers
IPhone sync with Outlook Calendar - Appointment time put on iPhone 1 hr later.
This solution pertains only to the one hour time difference people notice upon syncing to MS outlook.
In iPhone, there are two areas where you have an option to change your time settings.
1. When you go to 'settings', then to 'general', you can set up time and date, and also 12-24 hour format. Please note that changing the time here DOES NOT correct the problem, despite iPhone displaying correct date, time and time zone. Many people in this thread have stated that the problem persisted despite them setting appropriate time zone.
2. When you go to 'settings', then to 'mail, contacts and calendars' row (NOT the 'General' row) - you get an option to change your time zone at the very bottom of all the choices. You will see that wrong time zone is selected here - likely cause of the problem. Correct this choice and the one hour discrepancy between appointments in outlook and iPhone disappears.
Additional problem solutions - in the solution No. 2, if you set 'Time Zome Support' to 'ON', then all your appointments in the calendar will be displayed in the time zone of your HOME address. In other words, for example, if you are a person in central time zone, your appointments will be displayed ALWAYS in central time zone format - they will NOT change automatically when you travel from central time zone to eastern time zone. On the other hand, if you set the time zone support to 'OFF', then all your outlook appointment display times will change and adjust according to any time zone you travel to - This is often an inconvenience since most of us would like to remember our appointments as they were made in our home time zone, regardless of what time zone we traveled to.
Please note that the above solution pertains to only display of appoint times in outlook - This solution does NOT relate to the time displayed by iPhone and how that displayed time adjusts when you travel to different time zone away from your home time zone. This second issue is addressed below -
You can get your iPhone to display the current time in two ways -
1. Either always show the time in your home time zone, regardless of where you are (i.e., a person from Texas central time zone can set up to see the time always in central time, even if he/she travels to another time zone). This display setup is good for people who always think of time in their home time zone and then do mental conversions to reach at the local time zone time.
2. On the other hand, you can get iPhone to do this for you and change displayed clock time automatically to the local time zone that you have traveled to, away from your home time zone. Please note that enabling this capability in iPhone has no bearing on how the appointments are displayed in MS outlook.
Go to 'Settings'. Go to 'General' tab. then click on 'date and time'. Pick the 'set automatically' option to 'ON'. Now, the iPhone will automatically adjust displayed time to show the current time in which ever time zone you travel to.
If you set the 'set automatically' option to 'OFF', then you can select your home time zone. Then, the iPhone will always display time in your home city time zone and will NOT change even if you travel to a different time zone.
So, in summary, there are two places you need to adjust the time zones in iPhone - to do two separate tasks, first task of displaying appointments always in your home time zone upon syncing with outlook thereby avoiding the one hour skip; Second task of getting iPhone to display either your home time zone clock, or getting it to adjust current time to reflect the time in new time zone you travel to.
Hope this helps.
Date & Time of calendar
Sounds like your PC is not set to adjust for daylight savings.... the ipaq automatically adjusts for daylight savings but the PC does not. On your PC double click on clock, click on Time Zone tab and then on that screen you will see the box that needs to be checked. also check that both PC and IPAQ are set to same time-zones.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
