Pressed restart function. screen indicator "REstart Please wait" has been showing for 12 hours. it seems to be stuck. what is the problem? how do I fix this?
Please just tell me what is wrong and how to fix it
Try to perform full restart, press power button down until computer shuts down (+5 seconds). Then try to restart it. If repair function is offered, do not select that, select "start up windows normally".
Enter in service mode and clear this error: press aditional functions then press number 2 and 8 together and press again aditional function. Screen should display copier, on the screen press: copier/function/clear/err and then ok. Unplug the machine and wait 5 second then restart, if problem persist replace fixing heater
cud still be fuel issue-like the pressure regulator in engine area--throttle body mite be dirty as well as idle contrl motor --but sounds like some electric component is heatin up or distributer cap--coil--or ignition module is worn
Suggest using Acer eRecovery Management to attempt problem resolution as follows...
1. begin with the D250 powered off ...
2. if present, remove any external monitor (unplug its VGA connector from D250 left side)
3. power on and immediately press F2 to enter the BIOS / setup utility
4. using the right cursor key, cursor over to the Main tab of the InsydeH20 Setup Utility
5. if D2D Recovery is not enabled, cursor down to it, press Enter key and enable in pop-up
6. save any changes by pressing F10 to save and exit, otherwise press Esc to just exit
7. press Alt and F10 together while the Acer logo is showing to get entry into eRecovery.
8. eRecovery entry is indicated by message at bottom of screen "Windows is loading files...".
9. if not successful, power off, wait a minute then power on again and immediately
10. press Alt and F10 at the same time - do this several times while Acer logo showing.
11. once in Acer eRecovery Management (V7.0.10) screen, just leave it there........
12. if after a day or so, the screen has not changed, the problem is likely NOT hardware.
13. on the other hand, if your screen problem occurs after awhile, then it is hardware.
14. if it is not hardware, then your Operating System is likely corrupt or has a virus.
15. If it is not a hardware problem, you can completely restore system to factory defaults.
16. board level hardware repairs best done by sending D250 to Acer's authorized shops.
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. After the if you seen the screen dark then press FN+Right arrow in key board(>). When you press FN + ( </ ) or ( >) key that's time its working for brightness controlling for screen. Now if all well then fine other wise please let me know .
Another suggestion is run your HP driver DVD for installing Display drivers. When finish restart your laptop and watch whats going. If no success then format the Operating system & reinstall again.
Dear gap.com Customer,
Thank you for your email regarding the Sporty Printed Watch user instructions. Please accept our apologies that no directions were received with your order.
The instructions are as follows:
Button Functions:
A. Light B. Mode C. Start D. Reset
Standard Time Adjustment:
1. To set the time, press the Mode button three times (The seconds and the word Tuesday should start flashing).
2. If the seconds position shows less than 30 seconds, pressing the Start button will reset the seconds to 00. If the seconds position shows more than 30 seconds, pressing the Start button will reset the seconds to 00 and the minutes will increase by 1.
3. Press the Reset button until the area you want to change starts flashing (i.e., second, minute, hour, day, month, and weekend. Press Start button once for per unit increment, press and hold for 3 seconds for speedy advance.
4. At completion, press Mode button to resume standard time display.
To reset the Alarm:
Press the B: Mode button until you reach the alarm.
Press the D: Restart button.
Press the C: Restart button to get back to the time
