20 Most Recent
Canon ImageRunner 4570 | IR4570 | Questions & Answers
What means this code E000225-0001 ?
The light intensity of CIS is faulty.Disconnect and than connect flexible cable,if necessary replace it,or replace reader controllerPCB
8/28/2017 3:49:41 AM •
Canon...
Answered
on Aug 28, 2017
Error code 0001
try to reset the eror first * 28* .check thermistor check fuser heating element
1/28/2016 3:33:39 PM •
Canon...
Answered
on Jan 28, 2016
Why error code E000000-0001
it is the encode on the fixing unit / fuse unit change the fixing film and then reset the error code by entering service mode then clear it
1/28/2016 3:32:03 PM •
Canon...
Answered
on Jan 28, 2016
Paper jam?
my dear you change paper feed roler
8/12/2015 5:34:28 PM •
Canon...
Answered
on Aug 12, 2015
How to fix id card fuction
first entered in SPECIALFETURES then
IMAGE COMBINATION then (Machine Ask Original Paper Size)
Select A5R (if the LTR Size Show tuch the AB botton)
Select 2 on one then select A4 paper tray
Then Screen Show Special features
DO NOT TOUCH RESET or Any botton
touch MODE MEMORY select M1 touch STORE then done then OK
Press the Additional Function Bottoan
touch Copy Setting
touch Standred key 1 setting
(in this Window show many botton)
choose modememory Select M1 Select OK
afterthat your home screen show M1 on Bottem Left corner when you touch ID CARD COPY Feature activate Scan 2 Time Front /back Print on Combind one Side Enjoy!!!!
2/25/2015 11:30:37 AM •
Canon...
Answered
on Feb 25, 2015
Error code E000007-0000
Dear
1) Turn off and then on the main power switch. Is the problem corrected?
YES: Check the operation once again; if normal, end the work.
Connectors, DC controller PCB
2) Is the connection of the connector (J1015) on the main controller
PCB and the connector (J122) on the DC controller PCB normal?
Further, is the cable between these connectors normal?
NO: Correct the connectors/cable.
YES: Replace the DC controller PCB.
Thanks.
2/7/2015 3:42:33 PM •
Canon...
Answered
on Feb 07, 2015
Black colour lines in xerox only
Dear
If you have facing the problem while you made copy using ADF.then check th adf glass for scrathes replace it. If you have the problem while copy on platen glass then check lines on platen glass (rare case). Check cis for dust.
Thanks.
1/30/2015 9:38:52 AM •
Canon...
Answered
on Jan 30, 2015
How do I resolve the code e00010-001
Hi
I found the following description for your error
Description:- The rotation of the main motor is faulty.
Detection is executed every 100 msec after the start of motor rotation; however, the drive detection signal is absent for 2 sec.
Remedy:- Replace the main motor. Replace the DC controller PCB.
This was here:
Error Codes Canon iR4570 Code E010 0001
On this webpage where you can change the code you are receiving to a different one if required (or view them all) by using the drop down menus along the top of the page. You can also change the make & model using the drop down menus if you wish. You can also get a Service Manual from this page using the link.
Hope this is helpful, if so would you please register that with Fixya
Cheers
1/1/2015 10:04:07 PM •
Canon...
Answered
on Jan 01, 2015
