20 Most Recent
Tag Heuer 2000 Aquaracer WAB2011.BA0803 Wrist Watch Questions & Answers
How do I adjust date of my watch bought from GAP
Here is the manual from GAP customer service.
Dear gap.com Customer,
Thank you for your email regarding the Sporty Printed Watch user
instructions. Please accept our apologies that no directions were
received with your order.
The instructions are as follows:
Button Functions:
A. Light
B. Mode
C. Start
D. Reset
Standard Time Adjustment:
1. To set the time, press the Mode button three times (The seconds and
the word Tuesday should start flashing).
2. If the seconds position shows less than 30 seconds, pressing the
Start button will reset the seconds to 00. If the seconds position shows
more than 30 seconds, pressing the Start button will reset the seconds
to 00 and the minutes will increase by 1.
3. Press the Reset button until the area you want to change starts
flashing (i.e., second, minute, hour, day, month, and weekend. Press
Start button once for per unit increment, press and hold for 3 seconds
for speedy advance.
4. At completion, press Mode button to resume standard time display.
To reset the Alarm:
Press the B: Mode button until you reach the alarm.
Press the D: Restart button.
Press the C: Restart button to get back to the time
I need to stop alarm on watch MSP74576W
Hold right bottom button and then press right top button, while looking at tge watch face, this will toggle a little AL display indicator over the minutes digit
Hello, my new Tagheuer aquaracer calibre 5 500m
I have the same problem with mine....They have some kind of manufacturer malfunction , tag will not admit. My is in the shop for the 3rd time ...at this point they should replace my watch...this one is a lemon.
How doi get it off
you can just subtract 12 hrs from the actual time then you get the regular time. :)
Im trying to adjust the time because it stopped
mcdevito75 here, Tissot a very, very great name and watch, a you know most stems pull out to set the time, some watches have a screw down crown this adds to it"s waterproofing as there is a gasket under the crown. Maybe your Tissot has this screw down crown, simply un screw the crown then gently pull up on the crown to set the time. If this fails, see any Jewler for help, doN't mess with the watch to much a syou or anyone could wreck it, and Tissot is very expensive.
How do I switch from 24hr mode to 12 hr mode?
Check out the manufacturers web site, some manufactureres have users manuals for their watches which can be downloaded. You may be lucky. You could also try some of the various manuals websites. They have manuals for all manor of things. Good Luck
How to adjust the date in tagheuer watch
Some TAG models have a date "quick set". Pull crown out just a wee bit to position #1. Turn counter clockwise to advance date. Pulling out the crown to position #2 stops the watch and sets the time.
