Hard water is the reason for the spots. There is a new product out at www.dishwasherfilter.com that is made specifically to fix this problem. It filters the water going only into your dishwasher leaving your dishes spot free with every load. It is very affordable and guaranteed to work or your money back. You will love the way your dishes look after the very first load.
This is a classic sign of too much detergent. Are you only using one tablet? Too low of a washing temperature could also be your culprit. Dishwasher detergent needs to be washed with at least 120 degree water. Check to make sure your supply is hot (if it's plumbed to intersect with your faucet, just check faucet hot water supply temp). I'm not sure why you're running it on a two hour cycle, dishwashers can generally do the job in about 40 minutes. The grit is probably because there are food particles in your food trap. Make sure the food filter beneath the spray arm (if equipped) is clean and check the lowest areas for food scraps.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
