20 Most Recent Maytag MDB9600A Jetclean II Built-in Dishwasher Questions & Answers
Make sure the impeller is not jammed.
Maytag MDB9600A... | Answered on Nov 18, 2017
Yea sounds like one of the o rings have malfunctioned but there's no way of telling without checking every one but i think there's a pressure problem - a service should fix your problem...
Maytag MDB9600A... | Answered on May 05, 2017
Do you ever clean it with a dishwasher cleaning agent and run it on any wash mode?
Maytag MDB9600A... | Answered on Mar 09, 2017
Since the troubleshooting and repair process is too lengthy to include here, please go to the following link: http://www.appliance411.com/service/repairmanual.shtml
to open [or download] the service / repair manual. It is free.
Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
It includes a troubleshooting guide as well repairing instructions
Best wishes on your project.
Maytag MDB9600A... | Answered on Dec 01, 2013
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Maytag MDB9600A... | Answered on Feb 13, 2013
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Maytag MDB9600A... | Answered on Nov 16, 2012
try to clean the filter by taking off the bottom section of the water jet, it might be clogged, if that does not work, u got the same problem as me, it just wont drain. The pump is probably broken.
Maytag MDB9600A... | Answered on Jul 08, 2012
check your float valve to make sure it is movingt up and down.If it is then check your float relay switch
Maytag MDB9600A... | Answered on Jan 20, 2012
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Maytag MDB9600A... | Answered on Nov 15, 2011
could be a bad thermistor
Maytag MDB9600A... | Answered on Sep 21, 2011
Make sure the wire harness is secured properly to the pump . Also just make sure the drain line is clear. If this is not the problem most likely the control board needs to be replaced.
Maytag MDB9600A... | Answered on May 07, 2011
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Maytag MDB9600A... | Answered on Mar 27, 2011
The installation instructions and the Owner's Manual do not say how to replace the panel.  It may not be possible to change without replacing the entire door.
Look for trim near the top of the door that is attached by screws.  If the trim can be removed the old panel can be slid up and out and the new panel can be slid in.  Alternatively look for side trim piece(s) that might be removable allowing the panel to be slid in.
Maytag MDB9600A... | Answered on Mar 09, 2011
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
214 questions posted
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dishwashers
  • Maytag Dishwashers
Most Popular Question
maytag portable dishwasher not draining
  • Dishwashers
