20 Most Recent Amana 24 in. ADB1200AW Built-In Dishwasher Questions & Answers
I think my dishwasher's electrical
no but theres a fuse inside the door at the control panel,but a power surge on these usually ruins the units electronic control board
10/9/2014 6:37:14 PM • Amana 24 in.... • Answered on Oct 09, 2014
0answers
Amana ADB1200AWQ model dishwasher, built -in, bought replacement part for broken door lock handle. Any idea as to steps to replace it?
Just replace my door latch handle for the 4th time in 6 years. its very easy,,, you have the same as i do. latch and handle assembly i got from amana parts on the internet, # for part is W10130697. it is the same i think as a whirlpool part. call 877-827-5003 to order about 48 bucks. very easy to fix. Open dishwasher door and take out the tork screws ,you will see the latch with the 2 micro swithes on both sides, black on the right and white wires on the left. pull off the plugs , put the new door latch assembly in place and put the two plug bacl on micro switches, put back in all the tork scews and your set to go.... good luck... it is real easy.
12/29/2012 2:48:52 PM • Amana 24 in.... • Answered on Dec 29, 2012
Dishwasher shuts down during wash cycle
Could it be a thermostat proble?
10/10/2012 8:18:01 PM • Amana 24 in.... • Answered on Oct 10, 2012
WATER spinklers inside are not
Hello, answersfound I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>> http://home.howstuffworks.com/dishwasher.htm Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike http://beta.fixya.com/users/mc1bean
10/27/2011 8:36:25 PM • Amana 24 in.... • Answered on Oct 27, 2011
Dishwater will not fill...no water. Used to work
Not cleanable.Must replace.But check them first. They don/'t fail very often. Also check the obvious.Someone might have shut water off. Check for voltage at the fill solonoid .If voltage available then replace. If no voltage , Check ,door switch and,waterlevel switch. If ok, look at timer or controller.
Was this helpful?
8/16/2011 9:12:09 PM • Amana 24 in.... • Answered on Aug 16, 2011
My mugs and dishes are not coming out that clean
Try this first..
Go to your local Walmart and purchase a bottle of dishwasher magic.Follw the instructions on the bottle to clean the machine. in some cases this may take several attempts to clean out all of the hard water deposits...
Then use a product called Lemishine (about 1/2 full in the main wash receptacle and other half detergent) with a good powdered detergent this solves this problem 90% of the time.
If this does not help then further investigation would be required. Look for broken or damaged spray arms or anything the may be causing improper water flow.
6/7/2011 1:39:44 PM • Amana 24 in.... • Answered on Jun 07, 2011
2answers
Door latch problem
how to align the door to center the latch
5/16/2011 5:52:59 PM • Amana 24 in.... • Answered on May 16, 2011
0answers
2answers
Sandy grit left on dishes.
I was having a different issue with the same model but I think my issues solution might help yours. My dishwasher was not draining properly. It was the air gap that sits on top of the counter by the sink. It was clogged. We removed it and cleaned it out. Maybe if your air gap is slightly clogged as well it is not allowing the dirty water to flow out properly leaving you with gritty dishes. Hope this helps.
8/5/2010 12:14:23 AM • Amana 24 in.... • Answered on Aug 05, 2010
Fishy smelling dishes,
run some bleach in the D/W with nothing in it
5/2/2010 1:30:54 PM • Amana 24 in.... • Answered on May 02, 2010
Grinding noise in amana dishwasher
From what I understand, when it grinds, something has fallen into the filter at the bottom of the dishwasher. If you can, look in the filter and see if anything is in there. Eventually, it should stop once the dishwasher has ground up what may/may not be in there. Hope this helps.
3/27/2010 9:17:58 PM • Amana 24 in.... • Answered on Mar 27, 2010
The dishwasher will not turn on
CHECK TO SEE IF YOU HAVE POWER TO THE MACHINE. IF YOU DO REMOVE THE PANNEL AND CHECK THE DOOR SWICHES. IF THATS GOOD YOU PROBEBLY HAVE A BAD BOARD. If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
2/27/2010 5:12:37 AM • Amana 24 in.... • Answered on Feb 27, 2010
Water in tub bottom
You might put that disconnected hose into a bucket at the end of a cycle and observe the flow strength or quantity; you may have a pump whose internal seals or blades are worn and not pumping with enough speed to finish before the timer shuts it off.
12/24/2009 2:19:09 AM • Amana 24 in.... • Answered on Dec 24, 2009
I've ordered the parts to repair the latch on my
here is a web address to link you to it just happens to have a manual online here at www.fixya.com The link is posted below hope this works for you
http://www.fixya.com/support/p51530-amana_24_in_adb1200aw_built_in/manual-1748
12/1/2009 9:50:34 PM • Amana 24 in.... • Answered on Dec 01, 2009
Amana 24 in. ADB1200AW Built-In Dishwasher Logo
46 questions posted
Top Amana Dishwashers Experts
Mike Cairns
Mike Cairns
Kolbrun...
ADMIN Andrew
ADMIN Andrew
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Amana Dishwashers
  • Amana Dishwashers
Most Popular Question
dishwater will not fill no water used
  • Dishwashers
