20 Most Recent
Amana 24 in. ADB2200AW Built-In Dishwasher Questions & Answers
Impeller loose on pump motor shaft
The bore in the impeller is spun out. Mix some JB Weld and apply a liberal amount to the bore of the impeller, install it back on the motor shaft and rotate the shaft a 1/2 turn to distribute the weld before cure. Originally the impeller was a press fit. Don't allow food to get sucked into the pump, lock down and damage to the impeller will occur
No power seen at controls.
We had the same problem less than a year after we got ours. After two visits from the repairman, and a better business bureau complaint, they finally told us that there was a small opening on the inside of the door that allowed steam to escape into the area where the main circuit board is housed, causing it to short out. Replacing the circuit board and running a bead of silicone along the gap solved the problem. Hope that helps some!
The dishwasher is @ 5years old leaves dishes dirty?
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher
SprayArms not Spinning
How to Buy
ApplianceParts OnlineA bad heating element causes many problems in dishwashers...
Dishwasher Problems The
HeatingElement not WorkingDishwasherMaintenance
DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Will not drain water
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
My Dishwasher starts as usual,,,fills with water
Check the user guide manual. If resetting procedure is shown, follow it.
Otherwise the problem is with micro controller board. You have to contact the service provider as this is a computer program related fault.
If mechanical timer is used you can try cleaning them. But I doubt as the mechanical timers are no longer in use for the past few years.
Hope your incoming mains voltage is as per the recommendations!
110 V or 220 V as per your country standards.
Some times voltage fluctuations causes this problem. Should not be less than 10 % in any standard.
Cloudy Dishes
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Black residue
Maybe a ruber washer is breaking apart, But my advise is take the inside apart clean and inspect it and then test it.
