Does it have the network/print controller kit installed?
if so try this web site for drivers and scan manual Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Printing from an IBM AS/400 to a Konica Minolta 350 printer
An HP5si PCL5e driver may work for just basic printing.You will not have any extras like finishing or dulpexing.
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
SOURCE: I need to scan to email using the c353 konica
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
