Home Logo
r
ronald Posted on Jan 26, 2015
My jets are humming In the lasco luxury bathware how do I fix
Turned on the jets after filling up the tub and it just hums
Pump hums but nothing happens
Sounds like the pump impeller is stuck. Shut off the power and check to see if the pump has a small round cover on the end opposite from the pump. Some pump motors have a slotted shaft that you can insert a screw driver and manually turn back and forth to loosen the stuck impeller otherwise drain the tub and remove the pump to access the impeller and attempt to free it.
Hope this helps.
Bob
Great lakes hot tub humming sound
You either have a locked pump, impeller or stripped impeller on the pump shaft. Remove the jet pump assy and repair the pump and or impeller. You can also replace the pump assy.
No access hatch in tub when i press power buton it hums but no water from the jets no way to check moter or any other componet
If the motor is just humming when you press on the button to turn on the tub then you have a bad motor and it will need to be replaced
Feb 08, 2011 • Home
My bathtube jets don't work but there is a hum when I turn it on.
1. Is the tub filled with water?
2. Has it worked in the past?
3. Is the Intake Blocked?
There is often a turn knob for the speed of the recirculated water.
It may be valved down all the way
Jul 27, 2010 • Home
7helpful
5answers
My jacuzzi tub motor will hum but does not run. I
I had this same problem. I looked at the motor, and on one end (the end opposite where the water comes out) there is a hole in the middle. In that hole is a regular screw tip, which can be used to turn the motor. I filled the tub, inserted a slotted regular screwdriver and turned it about 8 times clockwise, then 8 times counterclockwise. You should see the whole motor turn. Doing this loosened it up, and then it started.
Once it started, all kinds or residue came out, which was probably why it had stopped working. I hadn't used it for a while.
After getting it running I'm going to run some cleaning solution through it, and make sure I run it more often to prevent this in the future.
6helpful
4answers
Jetted bath tub has stopped working. Motor hums
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 • Dishwashers
How to get jet covers on my lasco tub white they turned yellow
lasco jets usually unthread counter clockwise out of the wall fittings
Just moved into a condo with a whirpool tub. the
Jets are in the closed position or the pump is shot.
Sep 25, 2009 • Home
1helpful
Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
