Motor makes a sound ,drum doesn't turn and no water fills drum . The display panel bleeps and displays F36
SOURCE: Bosch Exxcel WFX
your brushes have gone in your motor you will have to go down to your local second hand shop and ask them to do it it will save you money and time it should cost a bout 20 to 30 to fix
SOURCE: The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
SOURCE: Have a WFL2480AU Bosch Front
Most likely to be the brushes in the motor that need to be replaced, check them for wear, and if less than 4 or 5 mm long, replace them.
Testimonial: "Great quick response."
SOURCE: bosch exxcel 1200 express washing
I had F63 on Bosch washing machine (Maxx 7).
I waited 5 days for a repairman and all he did was reset the washing machine processor, like this:
1. Turn the program knob to 6 o'clock
2. Hold the RPM button
3. While the RPM button is held, turn the program knob 1 click clockwise (to Rinse)
4. Release the RPM button.
This is similar to F21 which also happened to my machine.
Apparently both errors are related to power surge/power cut.
SOURCE: Bosch Exxcel Washer F21 error code
got a bosch washing manchine it keeps coming up f21 error and i have no book 2 see wot it is can you help me by tellin me wot it is thanks
