Dryers Logo
Rich Quezada Posted on Jan 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fridgidaire affinity faqe7011kwo no heat error code E5b any suggestions?
  • Official Brand Answer 2,267 Answers
  • Posted on Jan 27, 2015
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1290114
Points
2557
Good Afternoon Rich Quezada, thanks for your post!
From my understanding your Frigidaire dryer, FAQE7011KW0, is not heating properly. It could be a possible problem with your heater or thermostat. I would also recommend checking your vent to assure that there is no restrictions or blockage within the vents. This could also cause an issue with your dryer not heating properly. If you continue to have issue with your dryer I would recommend having a professional technician out to perform a diagnosis and repair on your dryer. Hopefully this is helpful. -Matt
2answers
Frigidaire Affinity Dryer FAQE7001LW0 won't heat. Error code E5b and E05.
Check the owners manual or manufacturers website for error codes. Most likely cause...a bad control board.You tube will most likely have "how to replace" videos for your assistance.
Good luck...
tip
Frigidaire Affinity Common Error Codes. (E4A, E9E, E56, E46 and more)
Hi.
This error codes apply to Frigidaire Affinity washers and dryers:
E11 - Fill time too long.
E13 - Water leak in tub, or air leak in air bell.
E14 - Reed switch.
E21 - Water not pumping out fast enough.
E23 - Drain pump relay on control board failed.
E24 - Drain pump relay on control board failed.
E31 - Pressure sensor not communicating with control board.
E35 - Pressure sensor indicates water overfill.
E41 - Control board indicates door switch is open.
E42 - Door remains locked after cycle is completed.
E43 - Control board problem
E44 - Control board problem.
E45 - Control board problem.
E46 - Control board problem.
E47 - Control board is sensing the door PTC circuit is open during spin.
E48 - Control board is sensing the door PTC circuit is closed.
E4A - Program Timeout Fault.
E52 - Bad signal from tacho generator.
E55 - Motor overheating.
E56 - High motor current.
E57 - High current on inverter.
E58 - High current on motor phase.
E59 - No tacho signal for 3 seconds.
E5A - High temperature on heat sink.
E5B - High temperature on heat sink.
E5C - High temperature on heat sink.
E5D - Communication problem.
E5E - Communication problem.
E5F - Communication problem.
E67 - Input voltage on microprocessor incorrect.
E75 - Water temperature sensor circuit (digital readout models only).
E76 - NTC temperature for the cold water valve over the limits
E95 - Communication error.
E9E -Voltage error.
EB1 - Incoming power frequency out of limits.
EB2 - incoming line voltage above 130 VAC.
EB3 - Incoming line voltage below 90 VAC.
EF1 - Clogged drain pump.
EF2 - Too much soap.
3answers
What does error code E56 mean?
That error is an E5b error. This indicates a problem with the heating element, the thermistor or the control board. You'll need to unplug the unit and access the wiring. Inspect the heating coil for breaks. Then test the voltage across the element (should see the line voltage) and check the resistance at the thermistor (should be ~50000 Ohms in a room temperature environment). If the above are okay, your control board is probably bad.
If you post a comment with the model number, I may be able to point you the appropriate parts. If your dryer is under warranty, contact Frigidaire.
I hope this helps.
Am getting error code E64 n my Fridgidaire Affinity dryer, and can't find out where I need t check for open circuits.
The E64 indicates a heater open circuit, heating element or burnt wire. If you can give me a model #, I might be able to describe were it is located.
On-Time Appliance
Sep 03, 2013 • Dryers
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Affinity aeq7000eeo e5b 006 error code
Probably a stuck button Use this SERVICE manual to locate your tech sheet and it will give you info on errors for your particula machine
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Frigidaire Affinity dryer error code?
you have a problem with the heat you can't just say it's the element or thermistor you have to unplug it,take it apart and get in there with a meter and check all the t-stats,element thermistor,if they check good you could have a bad computer board but hopefully it will be the element but if you just bought it the dryer is still under warranty for the first year so either call whoever you bought it from or the 800 number off of the machine
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
