LG LFD22860 Stainless Steel Bottom Freezer French Door Refrigerator Logo
Posted on Nov 12, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dripping water dispencer
Hi there just curious what can be done to stop a dripping water dispencer not alot of water dripping but still drips a bit anyone help meout.
  • Anonymous Jan 22, 2008
    January, 2008 here...just had it installed and very minor drip
    WILL THIS STOP????
  • ED20 Mar 04, 2008
    I just purchased my LFD22860 and water drips from the despencer. I'm hoping there is an easy solution.
Anonymous
Level 2:
  • Expert 489 Answers
  • Posted on Apr 27, 2008
Anonymous
Expert
Level 2:
Answers
489
Questions
0
Helped
299403
Points
854
Dripping problem is from 2 sources.  Faulty water valve or faulty water connector behind refrigerator.  If the dripping is constant and doesn't seem to end, then it's a faulty water valve.  If the dripping stops after awhile, then the water connector is allowing air into the water line causing the dripping.  Have that connection checked to make sure that it's securely in place.
1helpful
Vaillant boiler leaking only when heating switched off.
It would seem a joint has come a bit loose from the heating and cooling cycle. put a drip pan under the leaking area( the drips would evaporate quickly), then next time you shut it down go through all the joints in the area with wrenches to find the loose joint.
Water dispenser only drip water and litle bit ice made
If this unit has a solenoid for the water and one for the ice maker, they could be malfunctioning or blocked. Check filter first (if it has one) then check where the water enters the unit. There should be one or two solenoids to allow water to flow to each dispencer. They emit a "click" sound when activated. If not they will be faulty.
2helpful
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Water dripping from freezer section, into front dispencing area
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Inside water dispencer drips continually. Valves at back of unit were replaced but problem not solved
Unless you have another valve somewhere else, that is the only thing that could cause the problem. Have someone try the dispenser while you listen at the back and verify that the valve you replaced is the one the noise comes from when the dispenser is used. If it is, disconnect the line and watch to see if it is dripping. There could be sediment in the supply water that can stop the valve from closing. Low water pressure will also cause it to leak.
1helpful
Do I need to empty the water from my drip pan
the pan is there to catch condensation from the compressor during the refridgeration cycle. the water build up to me indicates one of two things. Either the refrigerant level is low and it is freezing up then thawing, or if you have ice or water dispencer it could have a leak in the line. the only thing other than that is a leak in the magnetic door seal or other insulation causing condensation. hope this helps
Our GE TFX22PPDA started oozing a sticky brown substance from the bottom left corner of the freezer door. We defrosted the freezer and cleaned out the drain. Next we checked the drip pan under the frig,...
I have a GE refridg. and a light, brown sticky liquid periodically drips from the water dispencer panel area. This started after we lost power for 5 days. What to do??
1helpful
MY WATER IS ALWAYS DRIPPING..HOW CAN I FIX IT?HELP
you may want to check your water presuure if pressure is to low the valve in the back of the fride is not closing properly or the valve is defective to check for this you need to remove the electric solenoid behind the fride leave the water line installed disconect the output tubingif it drips replace the solenoid valve [email protected]
Water drip at doorfront water dispenser
Hi!!! Yes you can fix it by installing an antisyphon device on your water line leading to the water dispenser..remember i've done this for many years repairing frigs and they all do this they all leak water out alittle bit..Good luck..
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
