Tried auto setup and also manual setup on web browser but nothing seems to work it says all good but won't connect to internet.
SOURCE: no internet connection on web browser
The problem may be in the router itself, prehaps a faulty product. But I am more inclined to think it is the outdated copy of windows 2000 which you use. In my view 2000 was second to Windows ME in terms of faults, errors, recoginizing hardware, and what have you. I would take the router back to walmart and test with a new one, but if that does not help, then it may be time for you to upgrade. Have you tried getting the ps3 online even without the computer having an active connection? Give that a shot and if for some reason the ps3 grabs the signal then it is time to give in for sure man. And watch the router when you try to connect the ps3 to see if it even attempts to grab the wireless connection, the wireless light will start blinking rapidly if it does.
SOURCE: Router Connectivity
It will be one of two things or both - either your computer is not
setup for DHCP or your router is using the same IP address as your ISP
or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To
configure your computer to use a DHCP IP address, go to the Control
panel => network connections => Properties (right click on your
default connection) => double click Internet protocol (From general
tab) => (a new window pops up) from the general tab ensure that
"obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
SOURCE: Router not seeing internet connection
If you are on cable internet, you need to perform MAC Address Cloning. Access the router's setup page using your main PC, under SETUP tab, there's a sub-tab called MAC Address Clone. Enable that and click on "Clone My PC's MAC" then click on Save Settings. Power cycle the router and the modem. You should be online after that.
SOURCE: Linksys wrt54g router won't broadcast my wireless internet!!!
find the back of router a small hole/pin then reset the booton then a 15seconds go go back normal the router.good luck
