20 Most Recent TP-LINK TL-WR740N Router Questions & Answers
I don't have the same router, but my router requires the reset button to be pressed and held for 20 seconds. Try that. Also, I have found the manual on-line. Try the link below:
https://www.manualslib.com/manual/534658/Tp-Link-Tl-Wr740n.html
TP-LINK... | Answered on Jan 19, 2019
Means no internet connection , better check the network connectivity properly.
TP-LINK... | Answered on Aug 20, 2018
Do the factory setting of it router n check its wifi without any wifi security enabled,if it's working fine then changed the security setting, hope this ''ll help u....
TP-LINK... | Answered on Jul 16, 2015
Milan have you got the user manual as it clearly explains how to set up the router and configure it manually !
http://www.tp-link.com.au/resources/document/TL-WR740N_V5_User_Guide.pdf
Your modem device already on your network has to have an IP address of 192.168.0.1 and according to the user manual the router detects the conflict in ip address and allocates its IP address as 192.168.1.1. If you IP address is different say 10.0.0.1 then you will have to plug just the router in to your Laptop and alter the i/IP address to 10.0.0.2 and turn off the DHCP server if the modem or existing router has DHCP. You will need to alter any existing DHCP server to have the first 10 IP addresses skipped for available leases to the computers.
TP-LINK... | Answered on Feb 07, 2015
My first take would be to make sure that the firmware is up to date. Often enough connectivity issues can be resolved this way.
Take a look at TP's support page here:
150Mbps Wireless Router TL WR740N
(Make sure you find the correct version of your router. I am also assuming you did not install any other firmware)
If this does not work, I would turn off any wireless security off to see if the phones connect. They definitely should both be able to connect at the same time.
Last resort would be to reset the router to factory default (make sure to have username and password from your ISP in case you need it.)
Let me know if one of these tips helped.
PS: What type of phones are you using? Android or iPhone?
TP-LINK... | Answered on Jan 19, 2015
http://192.168.1.1/
Wireless >
At SSID change that name
Channel: Auto
Mode: b/g/n mixed
Wireless Security >
WPA-PSK/WPA2-PSK
PSK Password: Here you put your password.
SAVE!
TP-LINK... | Answered on Dec 13, 2014
Unblock any blocked websites from from your router.
TP-LINK... | Answered on Sep 02, 2014
Is the router using wep, is the phone based on band n, change your wifi pass word system to something other than wep.
Check your wifi settings by logging in to your router settings though lan.
Switch off the power it will stop blinking.
TP-LINK... | Answered on Aug 02, 2014
For what?
TP-LINK... | Answered on Mar 28, 2014
If you reset the router, you return to the default setting. Then you have to create a new password. All of the settings you had before will be lost, including the MAC address, and security settings.
Here is a link of a video to help you:
TP Link TL WR740N Router Manually setup and configuration
TP-LINK... | Answered on Mar 23, 2014
Hey mate, did you mean that you want to access web management feature and change your Wi-fi password through iPad? If so you need to open the web management feature, go to Wireless > Wireless security and change your password there. Save and reboot, hope this helps
TP-LINK... | Answered on Feb 15, 2014
check channel , try to change channel to 6,11 . check the long way between your device and router . if not soluted , try another pc to check disconnection , if disconnected the problem with your wireless router , if not the problem with your wireless device
TP-LINK... | Answered on Feb 03, 2014
check the button of wifi on/off ,, then check SSID of your wireless appear or not . if appear the problem will be in lamp electricity. if not reset router . if not replace router .
fathima1980
TP-LINK... | Answered on Dec 23, 2013
Yes I am a setup wizard
TP-LINK... | Answered on Nov 20, 2013
TP-LINK TL-WR740N Router Logo
72 questions posted
Top TP-LINK Computers & Internet Experts
 Mike M
Mike M
alex metro
alex metro
Pamela Bates
Pamela Bates
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • TP-LINK Computers & Internet
Most Popular Question
setup wizard
  • Computers & Internet
