Got the top end open and the gears off the main shaft. Also took the screws out of the drip ring and can't get it off. Don't know if it slides off or screws off?
SOURCE: oil leak from planetary
The transmission center shaft seal/chimney is bad.You need to tear the transmission down in order to repair,let me know.
SOURCE: How do I remove the beater shaft on Hobart H600?
https://feg.hobartcorp.com/resourcecenter/Discontinued%20Product%20Documentation/F13447.pdf
Click Link above. It is you Instruction and parts manual.
Hope that helped
SOURCE: How to remove key from D300 Mixer to replace stripped gear
Keys are removed using a small punch and a hammer. The punch of choice is called a ***** punch
SOURCE: i have a t801 mixer with a bent planetary shaft.
Remove the whole planetary from the bottom... There should be a large nut on the main shaft...remove it ....whole assembly drops down...careful...don't drop it......At the top of the bent shaft you should see some center punches holding a thin nut in place.....drill them slightly so you can loosen the nut. There are some studs that hold the lower bushings in place...remove them with a straight blade that fits the screw snug. You can have a new shaft made out of stress proof steel shafting from a competent machine shop........MONSTROSPIZZA.COM
