20 Most Recent Hobart A200 Stand Mixer Questions & Answers
Hobart A200 mixer is blowing the two fuses. There seems to be no insulation breakdown or short circuit. Replaced fuses, it will work for awhile then will blow both fuses. What should I be looking for
Question edited to add maker Question moved from Cars and Trucks category. chaffing in the wiring harness, or possibly windings on the motor. There is a dead short somewhere. Service manual and wiring diagram.
A200 MIXER TECHNICAL MANUAL (ML-104858) (115/60/3)
Parts Town https://www.partstown.com > HOB-A200_spm PDF A200 Mixer 115/60/1 Technical ManualPage 2 of 43 ... Manual Bowl Lift ... If service is needed on this equipment, contact your local Hobart Service Office. 43 pages https://www.google.com/search?q=hobart+a200+blows+fuses ..
6/12/2023 12:30:16 AM • Hobart A200... • Answered on Jun 12, 2023
4answers
Hobart A 200 Mixer - Lube
HI Joe
I have the wrong greace in my A200 standmixer i need to know what kind and how much to put in gear cace. thank you
12/15/2022 1:56:14 AM • Hobart A200... • Answered on Dec 15, 2022
Hobart 20 quart mixer
Hi im a service tech for hobart.I cant give service manuals out because i could lose my job but i can step you thru your problem with the mixer,let me know.
7/9/2022 5:11:47 AM • Hobart A200... • Answered on Jul 09, 2022
HOW OLD IS MY MIXER
The Hobart A-200 is an 80's product. These first came on the market around 1985. There is no way to date the one you have without examining it. The best estimate is 25-30 years old.
6/3/2022 1:08:10 PM • Hobart A200... • Answered on Jun 03, 2022
4answers
I have a hobart a-200 mixer that had the brass
Loosen the two planetary nuts, should be a thin nut and an acorn nut. With these loose make sure the large nut on top of the transmission is tight. Push the planetary all the way up on the shaft and turn the thin nut up until snug. Back the thin nut off 1/4 turn. Hold the thin nut in position and lock the acorn nut against it. The planetary must have a very small amount of up and down play.
8/21/2021 5:34:51 AM • Hobart A200... • Answered on Aug 21, 2021
A200 electronic start switch
Hi harry,the wires should be marked 1-2-3-4,if not i'll give you the diagram.Let me know.
7/2/2021 1:02:16 AM • Hobart A200... • Answered on Jul 02, 2021
Hobsrt Mixer problem
Its ok to by pass the timer.You can bypass it and the switch will work.Let me get my service manual and ill post back on how to do it.
7/1/2021 2:30:10 PM • Hobart A200... • Answered on Jul 01, 2021
4answers
HOBART A-200 MIXER- FIRST GEAR NOT WORKING
Hi, your mixer was manufactured in 1947. Hobart does not make public their service manuals. It sounds like the diving key is not engaging first gear with the spinning shaft. This is the ticking sound you hear/feel. This could be because of a broken spring in the mechanism that moves this key in and out, or the key itself has become so worn that it will no longer engage the first gear. The unit needs to be opened up to remove all old grease and oil, including the planetary. The condition of the grease in your description of the planetary, is a good indicator of the condition of the grease in the trans. Your unit probably needs an overhaul due to it's advanced age and grease state. Unplug the unit. You can gently remove the two circular metal dust covers underneath the top cover. With a good flashlight you can view the overall quality of the grease and the level of it. In an ideal world the grease should fill the entire cavity and no oil should be visible. Replacement grease should be Shell Darina EP-2 or Chevron ALC EP-2. You'll need 4-14 OZ. tubes of either type to do the job. The Spec. # for your unit is 3943 Look for drawing # PL-985 Once the cover is off the trans., it's relatively easy to get to the diving key once you remove first gear (the large round gear on top). Remove what you need in sequence, and replace in sequence. If you have a digital camera, take lots of dissasembly pics. When you are done, test in all gears by turning the motor cooling fins with your fingers in the normal direction of the motor rotation. Do not plug the unit back in until you've tested all speeds manually. Good luck! ricardok45
11/2/2020 10:36:06 PM • Hobart A200... • Answered on Nov 02, 2020
2answers
HL 600 timer board I think
Sorry so late but the reason you need the kit is because the potentiometer (the knob that selects the time) is no longer part of the timer board.You need the pot,and board.I'm a hobart tech,if any other questions let me know.
10/18/2019 6:11:19 AM • Hobart A200... • Answered on Oct 18, 2019
4answers
NEED A WIRING DIAGRAM FOR A A200 HOBART MIXER
I had a look on google and came up with a service manual. not sure if this has the wiring diagram but the only other thing i can suggest is to contact te manufacturer direct. Go to http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
hope this helps.
7/8/2019 5:03:21 PM • Hobart A200... • Answered on Jul 08, 2019
2answers
Hobart speed issue
http://hobart.co.kr/manual_pdf//013.pdf this is a manual of parts, speed is controled by gears. if you are not sure of what you are doing call for service from hobart or an authorized tech. it is a messy job to boot.
4/24/2019 5:48:50 AM • Hobart A200... • Answered on Apr 24, 2019
Hobart A200 20 Qt Mixer Transmission
replace the speed select switch
11/10/2017 6:33:35 PM • Hobart A200... • Answered on Nov 10, 2017
2answers
Hobart A-200 serial # ?
Hi. Your mixer was manufactured in 1967. If you plan on keeping it, take the outer cover off, gently remove the two metal dust caps with a small screwdriver and look into each opening with a good flashlight to determine the quality and amount of grease in the trans. case.
Ideally the grease should almost fill the space with no oil visible. If you need to look further, I suggest that you open up the transmission cover, to determine the condition of the grease that lubricates the transmission. If you find that oil is seperating from the grease. you would do well to remove all of the oil and old grease and replace it with either Shell Darina EP-2, or Chevron FM ALC EP-2 grease. It's a messy job, but it will add years of life to your mixer.
Check the planetary seal, remove, clean and regrease the planetary gearing. With a mixer of this age, you never know if it has ever been serviced since it's manufacture or not. The grease must totaly encapsulate the trans. gears. As the grease breaks down it's level lowers and it leaves some of the upper gears without lubrication, and will result in preventable wear.
Good luck! If you found this solution helpful, please rate it. ricardok45
2/14/2017 3:45:23 PM • Hobart A200... • Answered on Feb 14, 2017
Speed reduction of Hobart A200 mixer
Hi Don. If your mixer is hurling honey, you must be very popular in the ant world...Sorry!
The Hobart electric motor on your mixer was designed and engineered to operate on 115-120 volt current and is the most dependable, and capable commercial mixer out there Is it possible for you to use a commercial Imerssion Blender for the first part of your mixing operation. Once your honey thickens a bit perhaps the a200 wouldn't hurl honey. Another consideration would be to either try a different beater or modify the one you have by removing surface area from the beater. If you remove metal, be sure to do it in a balanced fashion to avoid unwanted vibration in the beater. If you're not up to removing metal, take it to a machine shop and they'll do it for you. It probably won't take long, or cost much, and they have the expertise and the equipment to do it properly. If you found this solution helpful, please rate it. Good luck! ricardok45.
2/14/2017 1:42:02 AM • Hobart A200... • Answered on Feb 14, 2017
2answers
I hAVE A HOBART 200T FIRST AND THIRD GEAR WORK
I would say without looking at it a key is sheared or gear teeth are worn on the gear.usually its a sheared key,however if the mixer is older they use a dive key assembly which you would have to replace the shaft.I'm a hobart tech and repair these mixers often,any ? let me know.What is the ml # on the data plate?
12/13/2016 1:49:42 AM • Hobart A200... • Answered on Dec 13, 2016
2answers
Hobart 450 chopper mixer
Im a hobart service tech and repaired these units often,the seal job is a pain in the ***.Everything has to be torn apart.Forget manuals hobart doesnt give them out but i can step you through it.
10/19/2016 3:03:55 AM • Hobart A200... • Answered on Oct 19, 2016
How do I bypass Hobart A200 safety switch
we dont advise on how to disable safety devices ---and you dont want to disable a safety on a mixer that can rip a limb off and not even bog down
8/13/2016 7:13:59 PM • Hobart A200... • Answered on Aug 13, 2016
2answers
Welding bearing girdle for Hobart A200?
yes the cast can be welded(brazed). if you are able to weld this yourself, just remember before you can weld it, you have to heat it till it is cherry red then you can weld the piece. if your not qualified to weld it you can usually find a portable welding company to do this for you. hope this helps you please rate the solution...thanks
6/16/2016 3:46:35 PM • Hobart A200... • Answered on Jun 16, 2016
Hobart A200 Stand Mixer Logo
376 questions posted
Top Hobart Food Mixers Experts
vince
NOEL
NOEL
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
Hobart Food Mixers
  • Hobart Food Mixers
Most Popular Question
a200 electronic start switch
  • Food Mixers
