20 Most Recent Hobart H600 Stand Mixer Questions & Answers
Is it a Hobart? If so go to https://thesmartpartsestore.hobartservice.com/store/shopforparts and enter info for mixer in on top right and it will pull up the correct part manual for that unit and you can order what you need from them
Hobart H600... | Answered on Apr 25, 2019
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Hobart H600... | Answered on Apr 24, 2019
You can use a heavy weight gear oil or call the local hobart branch for it.To remove oil----Look under the mixer where the beater shaft is in the back and you will see a three quarter inch nut,remove this nut and drain the oil then put nut back in.To fill the unit remove the top cover screws and remove the top,you will see a long hexagon nut in length,remove this and grab a funnel then add the oil---be patient it takes time to fill as the oil is heavy.
Hobart H600... | Answered on Jan 30, 2019
there are two oils to change. one for the trans. and one for the planetary.the drain plug for the trans. oil should be in back of the planetary take out plug let oil drain ,remove top cover take outstand off where front screw to top cover threads into put new oil in there till you hit line in sight glass on right side of mixer.
Hobart H600... | Answered on Aug 16, 2018
Did you solve your problem?I'm a hobart tech but havent been on this site lately.
Hobart H600... | Answered on Jun 30, 2018
You can't. Contact professional catering removers. Or Two Men and a Truck.
There are only two parts, the head and the stand. They are pretty much equal weight.
Hobart H600... | Answered on Feb 24, 2018
I'm having the same problem cap and all look good but still the motor won't run and the the overload trips the breaker
Hobart H600... | Answered on Jul 14, 2017
Needed to know which part to open up to add or change oil on Hobart Mixer h-600
Hobart H600... | Answered on Mar 25, 2017
Not sure if you are asking if an H600 is automatically a single phase or a 3 phase and the answer is NO. Depending on the motor it will be 1 phase or 3 phase application. It will have 4 wires versus 3 wires -- hope that makes sense 3 of the wires are "HOT" on a 3 phase and only 2 are "HOT" on a single phase Motor.
Hobart H600... | Answered on Oct 31, 2015
One needs to know what the voltage and phase(1 or 3) the unit is and what the power supply is.
Hobart H600... | Answered on Sep 23, 2015
The machine can be internally rewired for 220 3 phase. Call your local Hobart office and have them come out and take care of it.
Hobart H600... | Answered on Jul 05, 2015
make sure the beater shaft is clean. is the dough hook new or old if its new you can deburr inside of dough hook to ease in install and removal of attch. please let me know so i can futher asist
Hobart H600... | Answered on May 31, 2015
You need to get a new electrician; a real electrician would read the power requirements on the motor name plate and install the correct voltage and amperage circuit.
A single pole breaker does not supply the same voltage as a double pole breaker. It hums because the voltage is wrong
Hobart H600... | Answered on Apr 08, 2015
1 gallon of 90w Gear Oil -- can be purchased from AUTOZONE! Make sure when you have completely drained from the large drain screw from under the mixer toward the back of where the attachments go on but not part of the part that spins around known as the Beater shaft! Once you have drained out all of the oil -- from the top where the front screw attaches the head or cap of the mixer -- add the oil there and make sure you are watching the sight glass to see when it is at the HALF way mark in other words when the oil level (TIP: Use a bright led flashlight to shine directly at this sight glass to view level) reaches to the midway mark of the oval sight glass, THEN STOP! It is full! Carefully start mixer on 1st gear and then 2nd so on and so forth to make sure everything is getting relubricated correctly and slowly -- don't just go setting it on 3rd or 4th speeds as you want to baby the mixer when you just put in new gear oil
Hope that helps!
Hobart H600... | Answered on Jul 22, 2014
Hobart H600 Stand Mixer Logo
137 questions posted
Top Hobart Food Mixers Experts
Ross Keen
Steve Allison
Steve Allison
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
Hobart Food Mixers
  • Hobart Food Mixers
Most Popular Question
oil change hobart h 600 mixer
  • Food Mixers
