Disney Princess TV/DVD Combo Logo
l
lindsy Posted on Dec 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i get vcr to work with tv
How do you get vcr to work with this tv?? how do i change input and what setting do i put it on? i've changed all setting and think i have cords hooked up correctly. however tv simply says no signal
Mikey
Level 3:
Top Expert:
  • Disney Master 6,904 Answers
  • Posted on Dec 30, 2014
 Mikey
Disney Master
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1623638
Points
26106
The connection would be ideally a SCART cable or a phono AV cable ( red, white, yellow) which are you using? Then turn on TV, then turn on VHS, if the VHS does not show on screen, press the AV/Mode button on remote until VHS on screen!
The buttons assigning DVD, TV, VCR, etc suddenly changed their assignments. DVD was now TV, VCR was now DVD, etc. I don't think it all happened at once either. Now I can't get sound from the...
There are facilities to CHOOSE the digital assignment. I've seen where extended power loss will randomly lose custom settings. Open the manual.
1helpful
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
3helpful
I connected my VCR to a new Samsung LED TV with the white ,red and yellow audio/video cable connection. The VCR is working but I put the tv and the VCR on Cahnnel 3 and it does not show up on the TV, WHY?
Hi there
To answer your question;
You need to change the input(not channel) on your tv to video input. There should be a button on your remote and/or tv called input.
Otherwise you should find it in the menu under"input source"
I can not change the input for VCR or DVD. I do
try to find a P+ and P- keys on front tv, and press P- until go AV. Try to find a remote on your local Electronics Store, they help you
Sony KP-53XBR45 rear projection TV: Coax input Selector Antena part on rear has the AUX input 'male' connector but the TV/Cable 'male' connection end is missing. Is there a way to use the AUX or any other...
You can replace the connector or if you have a cable box with audio and video outputs on it---connect them into one of the sets of jacks on the back of the set--switch to that input and change channels with the box----you can also do the same thing with a VCR--hook the cable into it and use its video and audio output jacks to connect to the video and audio input on the back of the TV.
In this case (the VCR does not have to work except as a tuner) you will go to whatever input you connect to and use the VCR to change channels.
These are a little less easy to use but costs you nothing---I am here to help, if you have any questions or need help let me know.
SD TECH
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Can not see the Video when I input it, see only a blue screen.
ok hook up the audio video in the OUTPUT on vcr and INPUT on the tv then make sure tv is changed to the right input channel now go to vcr and change that channel to AV,.if AV isnt there you may have to go into menu of vcr and do a channel search,but when you change it to AV on vcr you should see the picture
3helpful
2answers
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
2helpful
Hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
Top Disney Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
