20 Most Recent
Disney 13" TV Questions & Answers
Can u explain how to
The digital box should have a round threaded output connector on its back panel. These are usually marked "OUT TO TV" or "RF OUT" or something similar. There may also be a slide switch nearby to select channel 3 or 4 output to the TV. On some boxes the output channel selection is through and on-screen menu. You only need to connect the output of the digital box to the TV's antenna connector, then tune the TV to channel 3 or 4 depending on the box setting. Leave the TV on that channel all the time and do your channel changing on your digital box using its remote control.
If your TV has an AV input for connecting a device like a VCR or DVD player, you can probably connect the digital box that way. Most boxes provide stereo audio and video outputs, and you will get a clearer picture and sound if your TV has the input jacks. If your TV is not stereo and has just a single white input jack for audio (instead of red and white ones for stereo right and left), you'll need a Y-adapter to join the audio outputs from the box together to feed into the TV.
On the off chance you have a digital box with no RF output (I've never seen one since they need to work with older TV sets, but I don't know evey model), and your TV doesn't have AV inputs, you need an RF converter. The converter takes the audio and video signals from the digital box and generates the channel 3 or 4 TV signal that your set can pick up with its tuner. You can find RF converters at larger retailers and online.
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Cords
The yellow is video. Red and white are sound. If you are connecting a DVD you need to find INPUTS on your television. Depending on the age of your television and / or DVD, compatibility may be an issue. Try the internet for advice on your particular set as even some with HDMI inputs will only display picture and not sound. You could even ask at your local electronics store. Believe it or not, there are still some nice people out there. Not sure if this will help but good luck.
Dvd will not play movies
Are you trying to play a DVD-ROM? Some sets won't play anything but conventional movies, leaving you to put the disc in a computer to watch it...accordianman
What universal remote works with model number p1300nTV
I too own the Disney Pirates of the Carribean television. We have it setup in my boys' room so they can only watch DVD's, there is no cable connected to it. However, everytime we turn it on, we have to use the remote to change the input to dvd. The large Mickey button on the remote fell out and my daughter lost it. Without that button, you can't change the input at all. Therefore we have a perfectly functioning television that we can't use.
I emailed Disney and they redirected me to the actual manufacturer of the TV, Starlight Griffin. The phone number is 866-387-1902. I called and within 5 minutes, I was told that I would recieve my new remote within 10 days at NO COST TO ME!!
I went crazy for days trying to figure this out so I had to share that info with all of you immidiately! Good Luck!!
Strange screen
You will possibly need its original remote to remove them. Thanks for using Fixya.
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
