Sony FD Trinitron WEGA KV-32HS420 32" TV Logo
Kelly hensler Posted on Dec 12, 2014
Hdmi instructions Hdmi hookup
Dave P
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Dec 19, 2014
Dave P
Contributor
Level 1:
New Friend:
Answers
10
Questions
Helped
9505
Points
22
Hi Kelly,
I believe the Sony Trinitron WEGAs do not have an HDMI connection on the back of the TV. If they do it would be labeled as HDMI input below that familiar looking HDMI narrow horizontal connector. But I believe what you have is the RGB connector which looks like three round female connectors which are color coated Red Green and Blue. Now these RGB connectors are a form of high definition but it's not a direct connect for for your HDMI DVD player or your XBOX 360 or what ever you want to hook the TV up to.
You'll have to convert you HDMI to RGB. you can still purchase DVD players with RGB outputs but if you already have a device that requires a TV with HDMI, you can buy a converter. Go to RadioShack or BestBuy or search online for a HDMI to RGB converter cable . It should look something like the picture below.
RED GREEN AND BLUE for video. And then the white and red connectors that are banded together are for your audio.
Good Luck
1helpful
New 50" hisense tv .. unable to use hdmi for cable box .. tried different cables and all 3 hdmi outlets on tv ????
There might be a setting on your cable box for audio output. Use the cable remote and look in the audio section of the settings menu and select HDMI output. Mine is under Audio Digital Output in the Audio/Video menu.
tip
HDTV HDMI hookup
Connect a HDMI cable from your source device (cable box, Bluray, satellite receiver) to your HDTV for High Def video and audio. This is the best hookup for HD, even 1080p. For 3D HDTV, make sure to get a high-speed category 2 HDMI cable. Select proper HDMI input on the TV using the remote. HDMI means High Definition Multimedia Interface.
Any newer digital TV (made after 2008) should have at least one HDMI input.
https://sites.google.com/site/columbiaisa/diagrams_hookup_hdtv_hdmi
HDMI Cable
on Mar 06, 2011 • Televison & Video
Want to see dvd hookup for model#ln32b360c5dxza want to .Picturepicture of back of tv
See this link for the manual - looks like the hookup diagram is on page 6:
http://www.manualslib.com/products/Samsung-Ln32b360c5dxza-2824887.html
Can't see image with shaw pvr on toshiba 32hl57
I presume you followed the instructions in the TV manual during hookup and did not hook up with the units powered up and did select the correct input with the remote?
If you have another unit that uses HDMI try a direct hookup with it to see if the HDMI input is working.
HDMI units do not like being hooked up when units involved are powered up and on--seen more than a few where this was the problem and it is worth a try if the Owner Manual does not help you.
Got the digital set up box from Time Warner Cable but they did not include hook-up instructions.
If you have an HDTV, you can hookup HDMI cable from set-top-box to the HDTV's HDMI input and select that input on the TV using your remote. If you have analog TV, you can hookup using RCA cables (yellow to yellow, white to white). You could also call Time-Warner for assistance.
What cords do i need to up a DVD Player with my Loewe Concept tv?
Check ur DVD player and read ur instructional manual find out if ur DVD player have a HDMI port hub?Tries websites like Amazon.com,Ebay.com to buy a HDMI cable.That the esiest way to hookup a DVD player to a LCD or a Plama tvs.Just one HDMI cable to the DVD player HDMI hub and the other side of the HDMI cable to the tv HDMI hub.
I have a 32inch Phillips HD ready TV but there does not seem to be and HD input for my DVD player
"HD input" is HDMI. If the DVD doesn't have HDMI output then use the 5 wire hookup - the component hookup.
The TV input for HD would be HDMI or component input - 5 wires.
When i use a hdmi cable in my samsung dvd hd860 there is no sound, why is this
I had a Samaung DVD VR-375 and it plugged straight in and had video and sound both with one HDMI cable. BUT I also have 2 new LCD TV's that provide and additional audio hookup to go with the HDMI hookup. Look for an audio OUTPUT ( L and R) from your Samsung HD860 and electrically connect it to your TV input associated with HDMI marked L and R.
1helpful
My ps3 will work on the rca hookups but not on the hdmi hookups
When you hooked up the HDMI did you go into display settings and change all the PS3 settings to HDMI instead of AVI? I thought my HDMI wasnt working, just a blank screen but I could hear the sound, then it hit me..... change the video and display settings to HDMI and poof, there was the pic. lol
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
