20 Most Recent Sony FD Trinitron WEGA KV-32HS420 32" TV Questions & Answers
The power supply could be failing - only sporadically functioning.
Sony FD... | Answered on Nov 20, 2017
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sony FD... | Answered on Jun 15, 2017
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully.Visit this site " Electro help "for more details. Google for it.
Sony FD... | Answered on Apr 26, 2015
Hi Kelly,
I believe the Sony Trinitron WEGAs do not have an HDMI connection on the back of the TV. If they do it would be labeled as HDMI input below that familiar looking HDMI narrow horizontal connector. But I believe what you have is the RGB connector which looks like three round female connectors which are color coated Red Green and Blue. Now these RGB connectors are a form of high definition but it's not a direct connect for for your HDMI DVD player or your XBOX 360 or what ever you want to hook the TV up to.
You'll have to convert you HDMI to RGB. you can still purchase DVD players with RGB outputs but if you already have a device that requires a TV with HDMI, you can buy a converter. Go to RadioShack or BestBuy or search online for a HDMI to RGB converter cable . It should look something like the picture below.
RED GREEN AND BLUE for video. And then the white and red connectors that are banded together are for your audio.
Good Luck
Sony FD... | Answered on Dec 19, 2014
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given
Sony FD... | Answered on Mar 05, 2014
Display ratio usually is a setup choice but bear in mind that old movies and old TV programs will display in 4:3 ratio. Remotes usually have no control over screen size.
Sony FD... | Answered on Dec 28, 2013
The process is skilled one. Check this link for more details. It has details with screen shots. Pull up older posts there.
Sony FD... | Answered on Mar 22, 2013
It sounds that the standby light blinks, and the set do not turn on. These blinks are fault indications. Fromm these number of blinks, you can get an idea about the faulty circuit part inside. Count these blinks. How many occurs at one time switch ON. Count it for at least to times switch on. If you wish to get more details about the blinking codes to Sony TVs, check this site.
Sony FD... | Answered on Feb 26, 2013
how many blinks does it have.
Sony FD... | Answered on Oct 05, 2012
You have to replace all the micro-switches at its front panel switch board PWB.
Sony FD... | Answered on Sep 17, 2012
Number of flashes to this standby light are fault indications. Count the number of flashes occur at a time. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 700 posts to different brand TVs now. Pull up older posts there.
Sony FD... | Answered on Sep 05, 2012
Sony FD Trinitron WEGA KV-32HS420 32" TV Logo
70 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony kv 32hs420 keeps randomly switching
  • Televison & Video
