First make sure your cycle knob is not in the soak position. Then manually advance knob to the spin cycle. when it spins it should alternate draining water as it spins every few secounds,then it will spin up faster and finsh draing steadily.if it won,t drain during the spin mode then your control knob timer is bad. will it automatically go fron wash to end of cycles on its own with the knob moving on its own from wash to end of all the cycles if not then when it gets to spin or rinse it reaches a bad spot in the cycle advance timer not allowing the draining to be switched on as it advances thru the cycles.
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
SOURCE: Defy - 13KG Laundromaid 1300
Here's a solution I've gotten from one of the experts..
"Clean the drain motor lint tray/filter. So many 'faults' are
caused by blocked filters. The motor is unable to drain all of the water
in the allotted time.
If you are unsure where the filter is, it is normally behind the front
lower (kick) panel (or in some machines at the rear in an awkward
position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the
drain motor and ensure it is not jammed by a foreign object such as a
needle or a toothpick. It should be able to be turned by hand/finger-
the power IS OFF!
At this point it is also possible to test if the motor works. No clothes
or water in the machine, select a spin cycle and put the power back on.
You should be able to see the motor turning at some point, possibly
straight away. If it doesn't work then the motor is malfunctioning!"
Hope this helps.. Good luck! :)
I have a Defy Laundromaid 1300. I was getting an E9 message.How can I solve this?
