SOURCE: LG FRIG NOT COOLING
Hi have a nice day!
The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
good luck.
SOURCE: LG LRBN20514ST Bottom Freezer Frig cooling problems
Unblockin vents....great....but is the fan blowing. It blows air from the freezer to the fridge in accordance to fridge temp you set. If you find this helpful, please post as such or go live chat for faster answers. TY
SOURCE: I have a LG Fench door frig.with the freezer on
It is possible that the fanmotor is not working and needs replacing. If the fanmotor is working, then you have the defrost system checked. It is either the element which is gone or the main pc board.
SOURCE: Loud compressor noise from lg frig...
The sound you hear is the Freezer Fan, this problem is hard to diagnose, because the fan spins but not fast enough to circulate chilled air thru the freezer and refrigerator. The minimum labor and material cost for the repair/replacement is around $300.00. But if you chose to make the repair yourself the motor alone costs around [email protected]. But the repair is very labor because the electrical connection for this fan is at the rear of the unit
SOURCE: bottom frig is not cold enough. just connected after 1 yr
Ok do this. Boil some water in a pot then use that to defrost the freezer. This is caused by ice build up in the vent that is keeping the cold air from coming into the refrigerator. Make sure it is defrost completel though cause the ice that is built up is mostly inside and can't be seen. That will solve ur problem I guarantee. Then set the temperature to normal. Like half way. This keeps the frost from building up. Believe it or not as refrigerators get a bit older they actually get even colder and therefore frost build up is more likely. Since no refrigeration can be made completely leak proof, small amount of the freon has leaked out older fridge, and this actually cause it to get colder. You don't need a service technician just defrost then set to a lower setting thats it.
