Model number is: 11042926200 I believe all of the details are in the question above. Basically the washer won't start and we need to fix it.
SOURCE: Kenmore model 44142400 door lock
Try unplugging for 2 minutes and if display looks the same, then theres and elec. issue.
SOURCE: error code F9 for kenmore elite washing machine He3T
it will not let you unlock the door because the machines full of water?--the machine will not finish its cycle because the vacume switch is still detecting water , The water will not drain because the pump is blocked with something , probably a wire from your underwire bra,all you can do is undo a pipe undernieth and let the water drain away and take the pump to bits ?There may be an inspection cap somewhere on the front at the bottom
SOURCE: I have a Kenmore HE3t
There is a black plastic piece that sticks out from the machine. It is located at about
2 o'clock. You probably broke off the piece as I did with mine. If you have a wooden skewer (or something like it), stick it in and depress the button. You can glue the skewer in place.
That should fix your problem.
Testimonial: "the post on August 17th fixed my machine. It was the button on the door that was broken off."
SOURCE: kenmore elite he3 - door lock
fdl error code on kenmore elite he4 washer. wont start after selecting wash cycle
SOURCE: Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
