20 Most Recent Kenmore HE3T Washer Questions & Answers
it could be the felbelt
Kenmore HE3T... | Answered on Jan 26, 2018
Sometimes the sensor ion the door switch goes bad and causes this producible. I've had the issue, and unplugging the machine for a few seconds clears the error for me, but I suspect I will eventually have to replace the switch in the latch.
Kenmore HE3T... | Answered on Nov 29, 2017
I own a 18-year-old Kenmore front-load washer so I'm not sure this will apply, but here goes... My washer requires me to press and HOLD the start button for a few seconds before it will start. At that point the door will lock and the washer goes through its startup phase. I think that is a "safety feature' to keep from accidentally bumping the button and starting the washer. See if that help. Good luck!
Kenmore HE3T... | Answered on Nov 22, 2017
You reversed the fill hoses, switch the fill hoses you probably have hot to cold and vise versa.
Kenmore HE3T... | Answered on Jun 11, 2017
This tray empties during the spin cycle not wash cycle. Is the agitator spinning during the spin cycle? If so, you are getting softener on clothes during this cycle as required.
Kenmore HE3T... | Answered on Feb 17, 2015
The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with metal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement.
Thank you for contacting Fixya.com
Kenmore HE3T... | Answered on Nov 02, 2014
The troubleshooting section of my manual gives a Generic fix for F codes other than F20,F21,F22 as "Select stop twice to cancel the cycle.Select DRAIN & SPIN if there is excess water in the washer. Re-select cycle and press START If problem remains, call for service."
Not much help! Try checking the inflow by removing the hose to see if there is any debris in the inlet (rust etc.) Also could be a balance issue. Rearrange load and restart the cycle.
Or it could also be a leveling issue. Use a level to see if it needs to be raised or lowered by turning one or more of the "feet" with a crescent wrench to level the unit.
Kenmore HE3T... | Answered on Jun 28, 2014
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Kenmore HE3T... | Answered on Apr 13, 2014
Possibly an item of clothing between the door and frame. Unplug the washer.
Press gently against the door latch while you pull on the emergency cord.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kenmore HE3T... | Answered on Mar 18, 2014
Kenmore HE3T Washer Logo
322 questions posted
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
diagnostic test he3t stops c 01
  • Washing Machines
