SOURCE: BROTHER MFC-3240C
The printhead cant travel without prob in its rail. Try to pick up the paper which might stuck somewhere.
SOURCE: Unable to print. Error message Machine Error4F
here read this:
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001887&Sympt=How+do+I+clear+the+message+Machine+Error+4F+from+the+display%3f&Model=89&ProductGroup=5&ProductID=MFC210C
SOURCE: UNABLE TO PRINT
press menu then start bk copy then fourtimes arrow-up button (tel.index) quick after another.
machine will be in maintenance mode and lights will flash.
press start bk copy in case machine wont directly display the error code.
Error starting with 4 means defective print head.
Error starting with 5 menas defective purge station or cycle problems.
both error series means: you need a new printer...
Unable to.....
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
