Lands Phones Logo
Posted on Jul 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Analog line vs. digital line
Hi!
Recently I am subscribing for a digital TV+Internet+digital telephone package. Can you tell me, whether this phone is working on a digital line?
Anonymous
Level 2:
Champion:
  • Expert 211 Answers
  • Posted on Jul 05, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
211
Questions
0
Helped
75158
Points
371
I havent seen any phone system that would not work with digital lines. You might have to twik it for a disconnect times for conferencing though. You might loose a line if power goes off.
Cheers
On the DCX3635 Cable Box Gateway, Which uses IP Tv, trying to figure out,why the coax is plugged in, but if you're internet drops out you loose all tv... why is that? whats the point of the coax the
I believe that the Arris DCX3635 gets your subscriber information from the internet connection to your ISP. Without that information, it can't tell which channels you have subscribed to and should be able to watch. The coax cable carries all of the digital cable video content but doesn't have two-way communication with the provider.
Unfortunately, this is corresponds to the old satellite boxes that used the telephone line to get the subscriber information. That worked better since POTS didn't drop unless something broke/chewed on the wires.
I wish that I had better news for you.
(When setting up the DCX3635, the technician logs into an internal web page on the device. That's why I believe the gateway box gets the important data on the internet connection.)
Webopedia com
Asymmetric Digital Subscriber Line.
It needs an ADSL modem, a telephone line, and filters for all the phones in the house. Your existing telephone line must be enabled by your Telco to handle ADSL traffic. You can go on the internet and use your phone line.
2helpful
2answers
Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
How do I use the fax without going thru my computer just as a fax
Issue: How do I connect a telephone, answering machine or computer modem to my machine?
Solution: Connecting the telephone line and external devices to the MX310
Preparing the Machine for Faxing title-bar.gif Typical examples of connecting the machine are described below. The machine cannot send/receive faxes if the connection is incorrect. Connect the machine correctly.
i_important.gif Important
If the Power Disconnects Unexpectedly
If there is a power failure or if you accidentally disconnect the power cord, the date/time settings as well as all documents stored in memory will be lost. User data and speed dialing settings are retained. If the power disconnects, the following will apply:
bullet_s.gif You will not be able to send or receive faxes or make copies.
bullet_s.gif If a telephone is connected to the machine, you can receive voice calls.
bullet_s.gif Whether you are able to make voice calls depends on the type of your telephone.
sikaku.gif Methods of Connecting External Devices bullet.gif Connecting to an Analog Line t_01522.jpg
(A) Telephone line (analog)
(A) Telephone or Answering machine
Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A) . The machine may not operate properly.
bullet.gif Connecting a Telephone or Answering Machine via a Computer t_01724.jpg
(A) Computer
(B) Telephone or Answering machine
sikaku.gif Methods of Connecting the Various Lines The following are some basic connection schemes that apply when you are connecting to a non-analog telephone line. These are examples and are not guaranteed to suit every connecting conditions. For details, refer to the instruction manual supplied with the network device (control devices such as an xDSL modem, terminal adapter, or dial-up router) you are connecting to this machine.
(A) Digital Subscriber Line
(B) Splitter
(C) xDSL modem (splitter may be built-in to the modem)
(D) Computer
bullet.gif Connecting to an ISDN Line For details on ISDN connection and settings, see the manuals supplied with your terminal adapter or dial-up router.
Please be informed that you can access Canon's online support site for your printer by clicking here. You can find many solutions to your problems by searching their database once you have navigated to the support page for your model.
I hope this information allows you to resolve this issue. If not, reply back with a comment to this thread.
If so, please take just a moment to rate this post. Thanks!
Fax stopped operating when FIOS was installed
Verizon is lying to you. fax machines are ANALOG devices and will not work reliablyon DIGITAL phone lines.
2answers
I need a help line number its for my sister she is having trouble connecting to the internet please can you help
please tell who is your internet provider(i.e) whether it bsnl or airtel or tata indicom....like that....if you send this to me i can tell you quickly.....otherwise mail to id [email protected] will get the helpline no next min......
What is modem
Modem:
1) A device (modulator/demodulator) that allows computer information to be sent over a telephone line.
2) Equipment that converts digital signals into analog signals for purpose of transmission over a telephone line. Signal is then converted back to digital form so that it can be processed by a receiving computer. Modems are typically used to link computers via telephone lines. ...
3) Acronym for MODulator/DEModulator. A device that transforms digital signals from the computer into electrical impulses for transmission over telephone lines, and does the reverse in reception.
4) A modem (from modulate and demodulate) is a device that modulates an analog carrier signal to encode digital information, and also demodulates such a carrier signal to decode the transmitted information. A device that transmits digital data in tones over a phone line.
IN GENERAL IT IS A DEVICE TO CONNECT THE COMPUTER TO THE INTERNET.
For more detailed info about the modem click here
Hope this helps
Sammy
Lexmark x6150 unalbe to fax phone line is active using dsl
Hey Tony - Did you recently hook this up to the DSL for the first time? This unit is supposedly not able to work with a DSL line.
The fax modem in your AIO is an analog device and cannot be used on an ISDN, DSL, or PBX digital phone service. However, you can connect certain devices to your AIO that let you use the fax function in addition to these digital phone services.
To connect without an unsupported line:
Connect an active telephone cable from the AIO to the telephone wall jack.
To connect with an unsupported line:
If you use an ISDN phone service, you can connect to an analog telephone port (an R-interface port) on an ISDN terminal adapter.
For more help and to request an R-interface port, contact the ISDN provider.
If you use a DSL (Digital Subscriber Line) phone service, you can connect to a DSL filter or router that will allow for some analog (rather than digital) use.
If you use a PBX phone service, you can install an analog phone line for a fax machine.
If this was working on the DSL let me know. I don't know the location but obviously a separate phone jack is the easiest. Let me know. If this helps you fix it you can rate this as fixed. If you are just going to rate this as helpful I'd rather you please not rate it and just add a comment and say thanks for the info.
If you need more help just add a comment and I'll be glad to assist you further. Thanks.
Jeff
L75 vs DSL phone line
Fax machines are ANALOG devices designed to work with POTS (plain old telephone system).
Sometimes you can get away with a fax or two w/digital lines, but the machine will be very unreliable.
I don't think there is any damage as the machines have voltage limiter circuits built in. [except for lightning]
4answers
Can't fax
i could help ya with your problem
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
