20 Most Recent Canon FaxPhone L75 Plain Paper Laser Questions & Answers
2answers
I have a canon faxphone L75 with a check printer
Look on page 13-9 of this link to your Canon Faxphone L75 for Troubleshooting a Check Printer error.
http://gdlp01.c-wss.com/gds/0900007579/L75_User_Guide.pdf
4/3/2016 10:59:15 AM • Canon FaxPhone... • Answered on Apr 03, 2016
Why does my Canon faxphone L75 won't print and says needs new cartridge when cartridge is still good.
Some possibilities: Perhaps your cartridge isn't seated properly in the printer? Try taking it out again and restarting printer. Or, you could have a defective cartridge. Test with another cartridge. Pen
8/14/2014 6:19:08 PM • Canon FaxPhone... • Answered on Aug 14, 2014
2answers
Getting Error TX Report: Result 'NG' - what does this mean???
It means No Good or Not Good, fax was never received for a number of reasons.
6/5/2014 2:10:51 PM • Canon FaxPhone... • Answered on Jun 05, 2014
2answers
I need a driver for Canon Faxphone L75, working
As far as I can see from Canon website, there is adriver for Vista which may work considering that you change its compatibilitysettings to run in Windows 7.
Download the driver click here.
You may choose to run Program Compatibility troubleshooter or change thecompatibility settings. Steps are available in the article below:
Makeolder programs run in this version of Windows
For any help with driver updates, check this link out:
Updatedrivers.
2/19/2011 11:47:12 PM • Canon FaxPhone... • Answered on Feb 19, 2011
ALARM SOUNDED AND RED LIGHT BLINKING. SAYS CHECK
http://www.usa.canon.com/cusa/support/consumer/copiers_fax/thermal_laser_fax/faxphone_l75#ServiceAndSupport
Input 'check printer' and a few options will come up like removing power and and replugging the power cord or transformer back into the wall.
Or, reinstall the toner cartridge.
Solution: Reinstall the toner cartridge
  1. Remove the cartridge from the machine.
  • Remove any documents and printouts from the machine.
  • Make sure the machine is plugged in.
  • Lift the latch and open the front cover.
caution.gif Do not try to open the front cover without lifting the latch since this may damage your machine.
  • Hold the cartridge by its handle and remove it from the machine.
  1. When you are finished, reinsert the cartridge. Hold the cartridge by its handle and insert it into the machine as far as it will go, making sure that its tabs are aligned with the rails inside the machine.
  • Always hold the cartridge by its handle.
  1. Use both hands to close the front cover.
1/19/2011 4:56:47 PM • Canon FaxPhone... • Answered on Jan 19, 2011
I keep getting a
it might be that you have to uninstall the printer and then reinstall it. this will get rid of the error message
7/13/2010 10:50:50 PM • Canon FaxPhone... • Answered on Jul 13, 2010
Canon faxphone L75 will not print from computer
No I do not charge :-) , but you have problems with main pcb. You need to replace it, but its same amount of money if you buy new machine. Try with Canon L160 wich is also printer.
6/25/2010 7:26:16 PM • Canon FaxPhone... • Answered on Jun 25, 2010
When sending a fax it makes a clicking noise and
You need to do preventive maintenance - replace clutch, rollers, clean and lubricate,...
6/25/2010 7:11:15 PM • Canon FaxPhone... • Answered on Jun 25, 2010
When i send a fax there is a white line down the
Are you sure that there is no lines when you make copies?Because the scaner is used when you send faxes and when you copie, if sensor is bad or dirty lines would be wissible.
Clean it very well, with strong detergent, but in small amounts.Scratch the stains from corctour or similar...
6/14/2010 7:08:29 PM • Canon FaxPhone... • Answered on Jun 14, 2010
I am getting a white line down the entire page
Is it when u send or recieve faxes!If on sending(open the part where u put in the faxes to sent!U will see a big black roller and under that a small black one,undeer that a long strip of glass,make sure that there's no marks of any kind on the glass!If recieving it might be on the fax that is sending the fax!Good Luck!
4/26/2010 7:48:01 PM • Canon FaxPhone... • Answered on Apr 26, 2010
Have a Canon L75, want to know if we can access
U can only get the last 40 transactions on the fax report!sorry!
4/16/2010 7:43:33 AM • Canon FaxPhone... • Answered on Apr 16, 2010
Canon FaxPhone L75 Plain Paper Laser Logo
101 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
when sending fax makes clicking noise
  • Office Equipment & Supplies
