How do you adjust the clasp on the bracelet?
SOURCE: How to remove a Rolex jubilee bracelet
if its a real rolex, take it to a store dont play around with perfection. but the way a rolex bracelet is held on is by spring bars. look at the back of the watch and put a small screw driver in the lots and push down on the spring bar. then start to ease the bracelet out, now dow the same on the other side the end should come out
SOURCE: i want to adjust the steel bracelet on my new GMT II
You can do it yourself but proper watchmakers screwdriver is needed.
Check the sides of your bracelet and you will see screw ends with grooves. Unscrew them and adjust your bracelet (take the links out). Then screw them back in.
Regards
Arthur
