20 Most Recent Omega Seamaster 2541.80 Wrist Watch Questions & Answers
Seiko kinetic stainless steel bracelet has snapped
There are several easy to follow tutorials on u-tube. It's easier for you to look at these than for me to describe how it is done. Just search "adjusting steel watch straps"
10/2/2017 12:00:16 AM • Omega Seamaster... • Answered on Oct 02, 2017
0answers
Other than removing links, can
mcdevito75 here, You should right at the clasp, simply remove the pin and move the entire band up thru the other adjustment holes you see along side the clasp itself. If there aren"t any additional holes along side of the clasp for the band to move up closer to the clasp lock, then no other adjustments can be made.
8/19/2010 1:59:09 AM • Omega Seamaster... • Answered on Aug 19, 2010
I have a ladies omega seamaster watch. What is the
I hope that you are not considering replacing the battery yourself. Please consider that you will probably null and void the warranty by attempting this yourself, and as this is a very well made watch, I would HIGHLY recommend that you contact OMEGA for your watch services. That would be MY advice.
http://www.omegawatches.com/customer-service
8/14/2010 9:37:03 PM • Omega Seamaster... • Answered on Aug 14, 2010
My omega seamaster second hand is not ticking,
Would suggest having the watch serviced at which time a new battery will be fitted
4/29/2010 2:20:31 PM • Omega Seamaster... • Answered on Apr 29, 2010
3answers
Replace bezel for omega seamater
I would recomend taking it to an independent watchmaker. It should only be $15, $30 to make the change.
Most bezels are pressure fit. Using a small jewelers knife to pry the bezel from the case is how most bezels are removed.
My friend is a watch maker and he has a special tool that removes the bezel however he told me he only uses it when he has customers watching. Because the old knife looks pretty brutial, but works better.
4/29/2010 2:18:28 PM • Omega Seamaster... • Answered on Apr 29, 2010
Is an Omega seamaster copy waterproof? (And this
Generally it is safe to assume that copies are not waterproof although they be water resistant. Genuine omegas are sealed and compressed which is why a battery change at an authorised dealer (who will end the watch to omega) is approx £40.
2/21/2010 11:13:29 AM • Omega Seamaster... • Answered on Feb 21, 2010
Help! i have a misty face on my omega seamaster
Have you had it serviced recently or the battery changed in a non-authorised jewellers. It looks like your seal has gone. Omega need to be compressed after opening the back.
2/21/2010 11:11:38 AM • Omega Seamaster... • Answered on Feb 21, 2010
Why do the Omega Seamaster watches have a second
This is a helium release valve.
The purpose and function of the helium relief valve is a common point of confusion. It has nothing to do with normal underwater diving. Neither does it have anything to do with the depth rating for a diving watch. Helium does NOT seep into the watch while the watch is in water at any depth!
To put it simply, you can completely ignore a helium relief valve. This feature is not used in any way with any form of normal SCUBA diving or anything else that involves less than a multi-million dollar deep sea exploration project.
SCUBA diving activities normally occur at depths of no more than 120 feet. At 250 feet, air becomes toxic due to changes caused by the high pressures at such depths. For those who do very deep sea research, they often use diving bells, dry dive suits, and other types of very deep ocean exploration vessels. In some of these, a highly helium-saturated atmosphere is used to avoid the air toxicity effect.
The purpose of a helium release valve is for people who wear their watch inside the helium-saturated environment for an extended period. Because helium is the smallest atom, it will seep through the watch's seals under the high air (not water) pressures in this environment. If the watch stays in this environment for an extended time, helium will continue to seep in to the watch until the air pressure inside the watch (initially surface air pressure) equalizes to the air pressure in the environment.
This becomes a problem when the vessel is brought back up and depressurized. The helium which seeped into the watch over a couple of days, cannot seep out any faster. The excess pressure inside the watch needs a way to release faster than it seeped in. It is only in this situation that a watch needs a helium relief valve at all. If a relief valve was not on the watch, the excess pressure would likely escape by pushing the crystal out.
But, unless you are in this exact situation, you should never keep this valve open. While the watch is designed to maintain most of its waterproof abilities even when the valve open, it still serves no purpose and increases risk of damage to the watch to do so.
9/23/2009 7:00:39 PM • Omega Seamaster... • Answered on Sep 23, 2009
2answers
Omega Seamaster battery
Well maybe if you use a coupon then the price will be lower.
7/21/2009 11:54:58 PM • Omega Seamaster... • Answered on Jul 21, 2009
Don't Know how to ajust bracelet on seiko kinetic
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
3/28/2009 4:46:22 PM • Omega Seamaster... • Answered on Mar 28, 2009
3answers
How to remove link from band
The segments of your bracelet are held together with friction pins which have to be removed first in order to adjust it. This is a relatively complicated task requiring experience and a special tool to remove and return the pins and bushings back correctly without compromising the bracelet strength.
I recommend taking your watch to an Omega authorised dealer for adjustment while you wait.
12/18/2008 4:41:53 PM • Omega Seamaster... • Answered on Dec 18, 2008
Can i change my watche ?
it is still under warranty contact the ,manufacturer customer service and ask how to get a refund for the faulty item under warranty
7/10/2017 9:54:10 PM • Omega SeaMaster... • Answered on Jul 10, 2017
Can you tell me what year is my watch model 48613181?
Have you tried contacting the manufacturer of the watch ? https://ccm.omegawatches.com/en/ I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
2/28/2015 5:32:54 PM • Omega SeaMaster... • Answered on Feb 28, 2015
How do I set the chronograph on my manual Omega 1964 Seamaster wristwatch?
The chronograph resets at 0 on the recorder hands and the crono hand resets at 12:00 hope this helps.gabe
10/22/2014 2:44:32 AM • Omega SeaMaster... • Answered on Oct 22, 2014
Omega Seamaster 2541.80 Wrist Watch Logo
17 questions posted
Top Omega Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Omega Watch Expert? Answer questions, earn points and help others
View Most Popular
SeaMaster Omega
  • SeaMaster Omega
Most Popular Question
help misty face omega seamaster
  • Watches
