20 Most Recent Rolex Lady Datejust 179173SRJ Watch for Women Questions & Answers
2answers
SETTING DATE JUST ROLEX
After you unscrew the crown it is already in winding position. If you pull the crown, it will go to the date setting position. Further pull of crown will set it in time setting position. Try to pull the crown till you get it in correct date setting position and change the desired date. Do not use the date setting between 10pm - 2am, as this can damage date mechanism. The best way is to pull out crown to the time setting position and set the time to 6.30(anytime) and then push the crown in to date setting position and change the date to the previous day's date. Then again pull the crown out to the time setting position and advance hands forwards (clock wise) till hands pass 12.00 (midnight) and the date changes automatically to the desired one, then adjust the time, push the crown fully in and screw the crown on.
7/27/2016 8:39:02 PM • Rolex Lady... • Answered on Jul 27, 2016
Adjust jubilee bracelet
You bend it , literally take hold of the inside arch and bend it with your hands in not out this shortens the , the length and helps it close .
11/26/2014 10:47:25 PM • Rolex Lady... • Answered on Nov 26, 2014
Watch stopped last night. I tried rewinding watch numerous times but nothing happened.
The watch needs to be serviced. Its a great watch and the service wont be cheap but you will get it back in wonderful shape. A good repair shop can do this work, try a yelp search in your area.
10/8/2018 6:40:25 PM • Rolex Datejust... • Answered on Oct 08, 2018
Whirring noise inside rolex oyster
Some movement noise is ok, however it may be time for a service - Take it to any Rolex re-seller that offers repair or to any good timepiece service center. If its a vintage piece i would recommend sending it to Rolex, paying the extra cost to receive the watch with full Rolex repair documents and service history. The Rolex web site has information on this. Also this company does a fine job on Rolex repair. https://www.bobswatches.com/rolex-repair-service
2/11/2018 9:35:02 PM • Rolex Datejust... • Answered on Feb 11, 2018
Stem on my rolex won't screw all the way down
Its time for a service. Take it to any Rolex re-seller that offers repair or to any good timepiece service center. If its a vintage piece i would recommend sending it to Rolex, paying the extra cost to receive the watch with full Rolex repair documents and service history. The Rolex web site has information on this. Also this company does a fine job on Rolex repair. https://www.bobswatches.com/rolex-repair-service
2/11/2018 9:25:05 PM • Rolex Datejust... • Answered on Feb 11, 2018
Ive wound watch about 40 times it runs for about 3 minutes then stops again
I have the same watch 20 years old. I cannot wind this watch. it is self winding , which is generated by arm or wrist movement. i purchased a box for times I won't be wearing. Will rotate watch 5 minutes every hour ( belt driven- only use that other winders say gear my experience is belt drive more reliable) if you have to wind this watch I would question if it is real Rolex.
9/21/2016 5:29:12 PM • Rolex Datejust... • Answered on Sep 21, 2016
Why doesn't it keep running?
It needs to be worn to self wind. I actually bought a winding box so I put watch away it will be turned as if on your wrist. These vary and having owned a couple of winders I chose one that is belt driven, found on Amazon. if you wear it to sleep it may wind down. Playing video games ,little wrist motion, may find it stopped. you mentioned someone to.d you it was fully wound! How can they tell. I cannot wind mine if yours needs winding from stem you may not have real Rollex.
9/21/2016 5:20:15 PM • Rolex Datejust... • Answered on Sep 21, 2016
"Rolex oyster perpetual dateadjust" stops once in 2 days or less. starts on shaking the hand. advice?
try winding by using the crown see how long it goes for it may be the bob weight is not working or as come loose
7/16/2016 12:58:04 PM • Rolex Datejust... • Answered on Jul 16, 2016
Check watch serial number 754417
you cant check a serial number if Rolex dealer checks it he has to keep it if the watch is stolen Thanks Watchfinder Sean
12/9/2014 2:27:28 AM • Rolex Datejust... • Answered on Dec 09, 2014
0answers
0answers
Checking serial number
Luke, the serial number is located between the lugs at the 6 marker.You need to remove the wristband at that point to see it. The model number is located at the 12 marker.
4/4/2013 9:37:17 AM • Rolex Datejust... • Answered on Apr 04, 2013
0answers
Value of rolex Dayona 92 78488
At Ticker24, we take pride in making the most worthy and iconic timepieces accessible to all which is just as good as the authentic ones. Our passion and 15+ years of expertise in delivering luxury watches to our customers led us to this dream project of offering our collection of top-notch quality luxury replica watches. https://ticker24watches.com
3/11/2023 3:55:09 PM • Rolex Watches • Answered on Mar 11, 2023
2answers
Rolex st6 23zuan original or fake??
This is the hint regardless of Rolex. Look at the second hand and watch the motion! Does it sweep or tick? If it ticks it is battery operated watch knockoff. Rolex is a self winding watch thus the second hand sweeps does not click each second.
2/26/2023 8:26:14 PM • Rolex Watches • Answered on Feb 26, 2023
2answers
Can I take the back off a Rolex Oyster Perpetual Date Watch?
You can, but putting in back on and not cross threaded is a lot more difficult, plus it has a sealing gasket that need replacing. If you want to play with a $10,000 watch, fine. :>) Hold the watch firmly, turn the ball to the left until it starts to unscrew. Keep going until you can grip the back of the watch with your fingers and turn it some more. Pull the back off.
How to Open a Rolex Watch: 10 Steps (with Pictures) - wikiHow
https://www.wikihow.com > ... > Jewelry > Watches
1/4/2023 12:08:07 AM • Rolex Watches • Answered on Jan 04, 2023
3answers
Rolex Lady Datejust 179173SRJ Watch for Women Logo
Popular Tags
4 questions posted
Top Rolex Watches Experts
NOEL
NOEL
john h
k24674
Are you a Rolex Watch Expert? Answer questions, earn points and help others
View Most Popular
Datejust Rolex
  • Datejust Rolex
Most Popular Question
adjust jubilee bracelet
  • Watches
