20 Most Recent Rolex Oyster Perpetual Submariner Date Wrist Watch Questions & Answers
What is the number 381 on the back of my watch mean
For Casio watches, the number on the back is the module number. For ROLEX I have no idea. Never saw one in my life.
8/31/2014 4:29:57 AM • Rolex Oyster... • Answered on Aug 31, 2014
5/12/2014 12:16:58 PM • Rolex Oyster... • Answered on May 12, 2014
Adjust the bracelet
There are tiny pins either side of the wrist band next to the clasp. Remove these pins and you can take out up to two links (and a half link on some models.) A jeweller could do it, needs a special tool to tap them out and put them back
3/6/2014 7:06:32 PM • Rolex Oyster... • Answered on Mar 06, 2014
0answers
2answers
Submariner-how do I open it? I dropped it, and one
If it is a true Rolex they require a special wrench that grips the tiny serrations around the base of the back. You will need to take it to a watch repairman, the tool is very costly.
10/8/2012 7:12:33 PM • Rolex Oyster... • Answered on Oct 08, 2012
Remove links from watch
HelloGet into this link. You will get all the details from here.www.youtube.com/watch?v=1QqN5QBHdB4
1/30/2012 6:38:00 AM • Rolex Oyster... • Answered on Jan 30, 2012
tip
How to manage your SUBMARINER's size to fit your wrist
Take of your ROLEX, look on the inside of the bracelet. Near the area where you have the crown, there is a miniature circle, push with your thumb on it with strenght, you will hear a click . You pull your bracelet , it will open, then you look on the sides of the bracelet, and you insert a needle into the little screws on both sides, and then you choose the size you wish for your watch , and then put the circle back and close everything again.
Where are the model number and serial number on a
Thank you for contacting FixYa.
  • Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different.
  • 2
    Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step.
  • 3
    Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar.
    For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
  • 4
    Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase.
  • The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues.
    Hope this helps. Jewel
    10/8/2010 12:27:46 AM • Rolex Oyster... • Answered on Oct 08, 2010
    Value of rolex Dayona 92 78488
    At Ticker24, we take pride in making the most worthy and iconic timepieces accessible to all which is just as good as the authentic ones. Our passion and 15+ years of expertise in delivering luxury watches to our customers led us to this dream project of offering our collection of top-notch quality luxury replica watches. https://ticker24watches.com
    3/11/2023 3:55:09 PM • Rolex Watches • Answered on Mar 11, 2023
    2answers
    Rolex st6 23zuan original or fake??
    This is the hint regardless of Rolex. Look at the second hand and watch the motion! Does it sweep or tick? If it ticks it is battery operated watch knockoff. Rolex is a self winding watch thus the second hand sweeps does not click each second.
    2/26/2023 8:26:14 PM • Rolex Watches • Answered on Feb 26, 2023
    2answers
    Can I take the back off a Rolex Oyster Perpetual Date Watch?
    You can, but putting in back on and not cross threaded is a lot more difficult, plus it has a sealing gasket that need replacing. If you want to play with a $10,000 watch, fine. :>) Hold the watch firmly, turn the ball to the left until it starts to unscrew. Keep going until you can grip the back of the watch with your fingers and turn it some more. Pull the back off.
    How to Open a Rolex Watch: 10 Steps (with Pictures) - wikiHow
    https://www.wikihow.com > ... > Jewelry > Watches
    1/4/2023 12:08:07 AM • Rolex Watches • Answered on Jan 04, 2023
    3answers
    Hi hello can I asked here...I have a watch Rolex oyster perpetual datejust Geneva 18k
    The simplest way to find out is to take it to a Rolex specialist repairer and ask them to look at it. They will know what small clues to look for to find out. Some of the clues could be inside the watch on the inside mechanism so a watch repairer will have the tools to open it correctly.
    6/24/2022 1:48:39 PM • Rolex Watches • Answered on Jun 24, 2022
    Hello I have a watch Rolex Daytona,and I want to know if is original or fake .Can you please help me
    Fakes are getting better, but a jeweller removing the back will always tell the truth. There are some good videos in the link. https://www.google.com/search?q=rolex+daytona+fake+vs+original ..
    5/22/2022 4:33:12 PM • Rolex Watches • Answered on May 22, 2022
    Rolex electric watch not working?
    This link might help: https://www.google.com/search?q=HOW+TO+FIX+Rolex+electric+watch+not+working?&source=lmns&bih=568&biw=1366&hl=en&sa=X&ved=2ahUKEwi-y6HgsL_wAhXgBrcAHZ8lDvAQ_AUoAHoECAEQAA
    4/25/2021 4:07:03 PM • Rolex Watches • Answered on Apr 25, 2021
    2answers
    Mens Rolex Explorer. The no.
    Its not unheard of depending on the age of the watch (you say you purchased it 16 months ago but it could be a 15 year old watch.) If it was a new Rolex watch you have a 5 year warranty, so it should cost you nothing. If it was a pre-owned Rolex you should have received a warranty from your jeweler, most of those are 2 years. If this is a watch with value, and one you will either hand down or at some point resell then sending an older watch to Rolex is the proper direction - save all the repair documents, with the original receipt and the box. A Rolex Explorer II in good condition in US is about $5k, so $380 for a repair, though high, is worth it. I would recommend that if you do send it to Rolex for this repair and it is an older watch have it serviced too. The watch is returned to you in perfect condition with fill documentation. Lastly, you need not to send it to Rolex at all. Any good watchmaker/repair jeweler can do this for less than $380US.
    6/8/2020 11:43:48 PM • Rolex Watches • Answered on Jun 08, 2020
    What's the weight of Rolex Daytona 1992 78488 oyster cosmograph
    https://www.youtube.com/watch?v=RzQcj1ulIkQ "Five hundred dollars for a '93 Rolex Daytona," he says, "I'll do it!" That same watch is valued at around $16,000-$19,000 now, depending on its condition.Jul 30, 2012 https://www.exquisitejewelersmiami.com/blogs/rolex-daytona-watches/6351872-the-rolex-daytona Rolex Daytona Size and WeightDaytona watches are large and typically measure 40mm across. Weight for the Rolex Daytona varies based on the material used. For instance, it ranges from 148 grams for the stainless steel model, to 195 grams for the white gold, to 283 grams for a platinum Rolex Daytona. https://northscottsdaleloan.com/watch-reviews/rolex-daytona/
    4/29/2020 3:10:59 PM • Rolex Watches • Answered on Apr 29, 2020
    Rolex Oyster Perpetual Submariner Date Wrist Watch Logo
    Popular Tags
    16 questions posted
    Top Rolex Watches Experts
    NOEL
    NOEL
    john h
    k24674
    Are you a Rolex Watch Expert? Answer questions, earn points and help others
    View Most Popular
    Rolex Watches
    • Rolex Watches
    Most Popular Question
    number 381 back watch mean
    • Watches
