SOURCE: john deer
Hi if you look on the side of the oil pan there should be a square plate with 4 bolts the oil filter is behind it its a paper one Fram C139PL and a new gasket comes with the filter. I hope this helps. M.L
SOURCE: my father in law has a 1980 410d john deere
did they rebuild the hydralic pump and if so they need to do it again and check the valves in it
SOURCE: i have a john deere 2950 ''87'' it leeks hydrolic fluid
Lower load sense shaft seals are leaking.Remove bolts,small housing,washers,shaft then seals.You do need a special driver to get seals back in.Check load shaft for wear and when it goes back together make sure shaft goes bye the load sensor arm halfway through trans without to much force or you could damage load sense to rockshaft.This is a German made tractor.3150/2950
SOURCE: How do you check hydrolic fluid level in a John
Right side foot plate next to the rear end housing is a cap you screw off with your fingers. It has a dip stick under it.
SOURCE: John Deere x300 runs for about 30 minutes then stalls. There is no gas in the filter.
Check your fuel cap to make sure it is venting properly. If a vacuum is being created, and no air is able to get into the fuel tank, it will prevent the fuel from reaching the carburetor.
