When plugged into the charger the top light blinks green and the bottom light is solid red
SOURCE: red light on my jet 7 keeps blinking and chair barely moves.
Sound like the batteries are on their last leg. Have them load tested.
SOURCE: Blinking charge light on Invacare Zoom 300 scooter
Can you try another charger ?
Is it a onboard charger ? if so they do go wrong, Are they supply MK batteries ?
Check the leads from the charger connection socket to the motor controller board.
Regards
GeWiz.
SOURCE: When I plug in my jet 3 ultra the ammeter reads 0.
Its showing you the voltage out put for the charger if all power lights are lit and the chager is pluged in if batteries show only 2vlts then they are no good and the will not charge up thats why amp meter is on 0
SOURCE: The battery charger does not work. The red light
SEEK AN ELECTRICIAN WITH HIS METER WHEN SOMETHING GOES WRONG WE TEND TO THINK OF THE WORSE THINGS RATHER THAN THE BASICS,IM DISABLED MYSELF,THE BATTERIES ARE TO BE TREATED WITH RESPECT,I DONT KNOW WHAT CHARGER YOU ARE USING BUT PLEASE ONLY USE WHAT IS ADVISED BY MANUFACTURER,NOT ONLY THAT IF YOU DONT YOUR WARRANTY WILL NOT BE VALID.HAVE A NICE DAY COLIN.
