20 Most Recent Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Questions & Answers
Milwaukee 1/4 " impact driver has flashing red light
on the m12 impact, when you look in battery well or after opening 3 wires for to battery connectors, check the whites soldering and how many wires are actually soldered in the whites line ... just fixed buddy's who had exact issue and only 3 strands were soldered, stripped about a centimeter more and soldered back on and boom issue solved.
5/27/2023 7:13:55 PM • Dewalt DW056 18... • Answered on May 27, 2023
Can you use an 18 volt dc drill on a pier
No, you will damage the drill.Here's a fellow that tried it:https://www.youtube.com/watch?v=tfC-fKlPN7gYou can now buy waterproof drills although the price is something else: https://nemopowertools.com/- I've just re-read that and if you mean that the drill will NOT be in the water then yes, that's fine.
6/24/2016 6:40:49 PM • Dewalt DW056 18... • Answered on Jun 24, 2016
3answers
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
3/13/2016 4:30:36 PM • Dewalt DW056 18... • Answered on Mar 13, 2016
Dw990 chuck problem?
151359-00 a spring broken perhaps ? http://service.dewalt.nl/Products/ProductParts.aspx?ProductID=6301&BOMRegionID=1 http://service.dewalt.nl/Products/ProductParts.aspx?ProductID=6301&BOMRegionID=1
10/6/2015 9:57:23 PM • Dewalt DW056 18... • Answered on Oct 06, 2015
You will need he correct charger, the 24V will destry a very expensive battery.
3/18/2015 8:19:50 AM • Dewalt DW056 18... • Answered on Mar 18, 2015
Chuck is stuck OPEN black and decker power drill
Try beating on the side of the chuck with a rubber mallet and then try and close.
9/28/2014 6:20:36 AM • Dewalt DW056 18... • Answered on Sep 28, 2014
My 18v inpacter works fine with one battery but keeps stoping with the other when I try and use it
It is the problem of your another battery, you need to replace it.
7/14/2014 2:11:07 AM • Dewalt DW056 18... • Answered on Jul 14, 2014
The chuck on the dewalt impact driver does not hold the bit holder in
If you go to dewaltservicenet.com you can enter your model number to see the parts breakdown. It can be tricky to get the retainer clip off and on but the rebuild of the bit holder is easy other than that. The spring and the steel ball are all that usually need to be repalced. Hope that helps.
4/22/2014 4:20:10 AM • Dewalt DW056 18... • Answered on Apr 22, 2014
2answers
Can't get broken hex bit
what you need to do is remove the quick release mechanism. there is a retaining ring DO NOT STRETCH then a small flat washer and spring lift the collar and there are usually 2 small steel balls. then using a magnet you should be able to remove bit. this works only if the shank on the bit is not twisted.
3/19/2014 1:43:37 AM • Dewalt DW056 18... • Answered on Mar 19, 2014
0answers
There is no power when clicking the trigger
try another battery. If it still doesn't work it's either the switch or the motor. You can take it apart and hook the motor directly to the battery. If it runs the switch is likely bad. If not the motor is bad. Since it doesn't have servicable brushes you replace the motor. Be careful when you take it apart because the switch is static sensitive and you could damage it! Do the work at a static sensitive station.
1/27/2014 2:06:24 AM • Dewalt DW056 18... • Answered on Jan 27, 2014
Want to change keyless chuck
If your wanting the sleeve, #12 on breakdown, then search the part # as There are other places that still have it. http://www.ereplacementparts.com/dewalt-dw056-type-18v-cordless-impact-driver-parts-c-1009_9591_2845.html
12/29/2013 5:14:19 AM • Dewalt DW056 18... • Answered on Dec 29, 2013
How do i insert bit in cordless dewalt keyless hex
It only accepts 1/4" hex shank bits and nut drivers. Mine just pops in and to release it, you push the black collar around the bit down. Cannot put round end bits in it. Only hex shanks
11/29/2013 3:38:13 AM • Dewalt DW056 18... • Answered on Nov 29, 2013
Drill bit does not stay gripped, chuckless drill
On this particular tool, you can't really tighten the bit in the anvil like a bit in a drill chuck. The bit is free floating but held in place by a small steel ball. The steel ball is held in place by the sleeve that slides up and down to release the ball so the bits can be changed. The sleeve is held down by a spring. Bits falling out can be caused by: Using bits without the groove in the bottom of them for the ball to catch in, dirt in the bottom of the anvil so the bit can't seat properly, the ball is missing or stuck, the spring is broke or binding, or the sleeve is bent or too dirty to slide up and down freely. Use compressed air to clean the anvil well and WD40 to clean and lube it further. If bits still fall out you'll have to take it apart and see if the ball, spring or sleeve need to be replaced.
1/15/2013 9:20:54 PM • Dewalt DW056 18... • Answered on Jan 15, 2013
Dewalt 825 impact how to use
go to dewaltservicenet.com and you can download the operators manual with detailed instructions on tool operation. If you need more assistance let me know.
10/12/2011 2:45:08 PM • Dewalt DW056 18... • Answered on Oct 12, 2011
My dewaalt impact driver all of a sudden runs with
sounds like the variable speed portion of the switch is faulty, the only resolution is to replace the switch. Go to dewaltservicenet.com and with your model number you can download a parts breakdown and also order the parts needed. MAKE sure to write down the wiring of the switch before removing, it is polarity sensitive.
8/31/2011 2:09:44 PM • Dewalt DW056 18... • Answered on Aug 31, 2011
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
86 questions posted
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
View Most Popular
Dewalt Drills
  • Dewalt Drills
Most Popular Question
want change keyless chuck
  • Drills
