20 Most Recent Kodak EasyShare M863 Digital Camera Questions & Answers
Go to Kodak site and find out the significance of the blinks and you will be guided accordingly.
Kodak EasyShare... | Answered on Sep 03, 2017
If other memory cards take the format then your card is fubar.
Kodak EasyShare... | Answered on Aug 25, 2017
In that case, return it to Walmart
Kodak EasyShare... | Answered on Jul 16, 2017
Go into settings, close wi fi and blue tooth. change screen brightness , change time on screen shut down.
Kodak EasyShare... | Answered on Oct 29, 2014
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Kodak EasyShare... | Answered on Jan 16, 2014
i want to know if there is some flash to use in video way with my chamber
Kodak EasyShare... | Answered on Jan 03, 2014
make sure the setting is on auto or something . check the knob at the top .
 if your internal memory is full, then you need to either put the pics on the computer or delete them . get a memory card so you have more room .
try taking out the battery for a little while or charging it .
if your niece deleted it all then it's gone , i'm sorry .
Tente obter nova bateria
Ele vai trabalhar novamente
Kodak EasyShare... | Answered on Dec 10, 2013
then ur flash could be broken
Kodak EasyShare... | Answered on Nov 29, 2013
There's a selection of batteries with and without a charger here.
Kodak EasyShare... | Answered on Feb 23, 2013
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Kodak EasyShare... | Answered on Feb 13, 2013
This is common on these models, needs service/repairs.
Kodak EasyShare... | Answered on Jan 24, 2013
Press the MENU button. Use left/right-arrow to select the Capture tab (the camera icon without the "+" sign). Use up/down-arrow to select "Date Stamp" and press the OK button. Select "Off" and press OK.
Kodak EasyShare... | Answered on Oct 17, 2012
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
284 questions posted
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
minha camera digital liga e desliga
  • Cameras
