Sony Bravia XBR-Series KDL-37XBR6 37-Inch 1080p LCD HDTV Logo
M
Marilyn Posted on Sep 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is broken on a Sony Bravia KDL-37XBR6 when the tv won't come on and the standby light flashes 6 times? We would like to try repairing it ourselves.
Thomas Beaver
Level 3:
  • Master 2,119 Answers
  • Posted on Sep 26, 2014
Thomas Beaver
Master
Level 3:
Answers
2119
Questions
0
Helped
752119
Points
6319
1 Related Answer
Anonymous
  • 1961 Answers
  • Posted on Mar 18, 2011
SOURCE: My Sony MDRF810RK wireless headphones
Hello!
I must inform you that most of the wireless headphones has an automatic shut-off which puts it in stand-by when there is no sound going in to it. Or if the sounds in the tv is too quiet the headphones will think you have finished using it.
What you need to do is increase the volume setting of the TV. And turn the volume control on the headphones down then as well - assuming that your headphone base unit is connected to the headphone socket of the TV.
Let me know if you want me to help you further.
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
KDL-52w4100 won't turn on and LED blinks 6 times
Bus clock and/or data lines low at power on. 6 blinks of standby light denotes this. Actually, it should be a motherboard problem. Your TV need a thorough checkup before confirmation. If you wish to get more details about the blinking codes to Sony TVs, check this link.
1helpful
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
My Sony 32inch is blinking in standby mode and won't turn on
Sorry to tell you this i have the same TV.I have just checked the manual it says TO count how many times the light flashes in 3 second intervals.Then turn the tv off and un plug it from the mains.Sorrry then you will have to ring the Sony service centre and explain the problem.
1helpful
My KDL sony tv turns on briefly(displays menu) then shuts down, and standby led flashes 6 times then pauses then continues, does not respond to the on/off button or the remote
6 times blinking standby light indicates problem with Audio Section in tv
Check AU 15V output of G2 (power supply) board then check AU board as it has sound processor and sound output ICs.
If you are not familiar with electronics stuff repair then call local tv repairman to repair it for you.
Thanks.
My Sony Bravia, model KDL-46XBR4's standby light is flashing 6 times. We have reset it 3 times but after several days it shuts down and continues to flash the standby...always 6 times. Can anyone tell...
I am experiencing exactly the same problem. TV turns on but within 60 seconds the screen goes black and the red standby light blinks six times. Were you able to resolve this problem on your TV?
1helpful
Sony Bravia standby light flashing 6 times
there is a bad ground may on the cable check the voltage on the cable & set if on cable call the cable company. if tv call sony they may help with cost may be still under warranty
4helpful
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
