Sounds like a bad check valve or hooked up wrong the soap should siphon in could valve fitting be in backwards, or in wrong place I use a separate siphon valve that fits between pump out let and high pressure hose.
Pressure washers usually will not draw soap on high pressure setting. Switch wand or set wand to lower setting. Pin hole leak in soap line can also cause problem.
Water remaining in soap dispenser. In front loading washers made by LG (some Kenmore too), water may remain filled in the soap dispenser after the wash cycle. This may be caused by the siphon tube being contaminated by detergent residue. To clear it, remove the siphon cover from the tube, and clean them thoroughly, making sure that all residue is removed. Replace the cover and make sure it seats properly all the way down. This will ensure that the siphon starts and continues until the dispenser tray is emptied. A small amount of water, a half inch or less, remaining is normal. There is a video on YouTube that suggests buying a new detergent tray. Try cleaning it first. There are no parts that will break or wear out under normal use.
The siphoning mechanism on almost all power washers use "The Venturi" effect to suck up the detergent. Basically, there's no pump...the force of the water passing the siphon hose causes a vacuum which draws the detergent up the tube. There's a small ball that is supposed to fall and block the tube when the trigger is released so it sounds like it got jammed up in there somehow. You could it apart and free it up but I would recommend just purchasing an external detergent dispenser. Home Depot carries them for about 15 bucks. They allow you to use soap with high pressure and bypass the always problematic siphon system.
Based on the symptoms you are describing, it sounds like the siphoning mechanism or water valve is clogged up. Scum will build up in the siphon tube and stop the liquid from going into your washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. Try removing the soap dispenser drawer and the insert in the dispenser as well for cleaning. Reinsert the drawer once it is clean and dry.
If the abovementioned tips do not resolve your issue, I would recommend having a service technician to accurately diagnose the problem before investing in unnecessary parts.
The red knob is to regulate the pressure. The soap siphon should be hooked up to the pump at the high pressure outlet and the pressure hose hooks up to it. You do just have to drop the tube into your soap solution but I recommend you dilute the soap down as the siphon usually sucks the solution up fairly fast. The trick to making it work is to use the low pressure, soap tip on your wand. They are black and help fan the water/soap out but give no resistance to the water coming out. If you are using a high pressure tip, usually red, yellow, white or green, there will be too much back pressure in the hose and siphon attachment for it to **** up any solution.
This is inevitably caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
Most pressure washers introduce soap into stream of water by the siphon method. In order for the system to siphon the pressure tip must be changed to one with large opening. Once the large tip is install, the fast moving low pressure water thru the hose and wand will draw-in soap. With the pressure tip installed soap will not be drawn-in. To spray soap and water under pressure use a large container (larger the better like clean 30 gallon trashcan) and fill with clean water and measure of liquid detergent. Use short water hose from with-in container and connect to pressure washer as normal. Keep checking water level so that washer will not run dry. Most pressue washers will **** water in quickly from container, however you can pre-fill the water hose with water to speed things up. Trailer mounted pressure washers use a very large container for water. You can estimate how log the pressure washer will take to use the water by checking the gallons per minute rating of your machine. Good luck
