20 Most Recent
Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure Washer CARB 020487 Questions & Answers
Why the water is running from detergent siphoning tube?
The siphoning mechanism on almost all power washers use "The Venturi" effect to suck up the detergent. Basically, there's no pump...the force of the water passing the siphon hose causes a vacuum which draws the detergent up the tube. There's a small ball that is supposed to fall and block the tube when the trigger is released so it sounds like it got jammed up in there somehow. You could it apart and free it up but I would recommend just purchasing an external detergent dispenser. Home Depot carries them for about 15 bucks. They allow you to use soap with high pressure and bypass the always problematic siphon system.
Pressure washer was running and it back fired. now
CALL YOUR LOCAL PARTS STORE AND SEE IF THEY CARRY C-FOAM. IT IS A LIQUID THAT YOU POUR INTO THE CARB, LIKE YOU WOULD A LITTLE GAS TO GET IT STARTED. BUT THE C-FOAM WORKS MUCH BETTER AND WILL CLEAN OUT YOUR PROBLEM AND SHOULD GET YOU GOING. I HAVE UDES IT SEVERAL TIMES FOR VARIOUS PROBLEMS AND THIS STUFF IS WORTH EVERY PENNY. THEY MAKE 2 KINDS OF C-FOAM. READ THE DIRECTION TO BE SURE YOU ARE GETTING THE RIGHT ONE
