Refrigerators Logo
A
Anonymous Posted on Sep 24, 2014
Whirlpool Side by Side. Husband replaced fan motor inside freezer. Ever since it's been replaced, it runs frequently and hums loudly. Any suggestions. He took the interior back out and it doesn't hum.
Recently replaced the icemaker assembly. After replacing that, the fan in the back of the freezer starting making terrible noise, (almost like ice was forming back there and fan was hitting it or something). So husband replaced fan motor. Ever since, it has been very loud and runs frequently. He tried taking the interior back out (the whole inner back plate or wall that screws down) and it quit, but when he put it back it is humming loudly again. We are about to go nuts from the constant noise.
HomeApplianceService
Level 2:
Scholar:
New Friend:
  • Expert 123 Answers
  • Posted on Dec 06, 2014
Expert
Level 2:
Scholar:
New Friend:
Answers
123
Questions
0
Helped
36317
Points
216
The fan blade touching the interior back cover????
May be the fan motor shaft is too long or may be he did not push the fan blade well inside into shaft so it is to much out. Thus touching the wall cover plate..????
5 Related Answers
Dave Harrison
  • 114 Answers
  • Posted on Sep 28, 2007
SOURCE: Humming in Whirlpool Side by Side Refrigerator
It is probably just your water inlet solenoid being activated. Not to be concerned.
BNewberry
Bill Newberry
  • 93 Answers
  • Posted on May 15, 2008
SOURCE: Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
douglas smith
  • 1462 Answers
  • Posted on Aug 23, 2008
SOURCE: ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Anonymous
  • 750 Answers
  • Posted on Sep 29, 2008
SOURCE: my whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
rpbuice
Ron Buice
  • 161 Answers
  • Posted on Dec 16, 2008
SOURCE: ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
1helpful
My whirlpool side by side fridge/freezer is making a loud noise while running.
If the noise is coming from inside, the evaporator fan motor (the fan motor that circulates cool air located in the freezer section) may be the culprit. If noise is on the outside, the condenser fan motor may be the problem. This is the fan motor that removes the heat from the refrigerator to the room.
Samsung rs2530b refrigerator making loud noise...why?
It might have dust in it. It can drain the fan speed, which makes odd sounds. It could be something else jammed in there too. Clean the fan and see if that works.
1helpful
I have a kenmore side by side refrigerator freezer. It's about 15 years old. Recently the freezer has started making a loud humming noise. HELP
Good day,
The most common reason for noise is the fan motor in the freezer compartment.
Remove the screws from the rear panel in the freezer compartment and inspect the fan motor. Replacing it is a fairly easy nuts and bolts procedure. The motor should be available at most appliance parts houses.
kenmore is a trade name for Sears appliances. It was made by either Whirlpool or Frigidaire.
3helpful
The ice fan is making a loud humming noise
Hello and thank you for using Fixya's services.
I am not an expert in this field but I did have the same exact problem and called a service technician. There was huge block of ice in the back panel of the freezer.
Get everything out of the freezer and take the panel off the back (inside of freezer) with a screwdriver. Look by the fan and check the bottom to see if there is a build up of ice. You can pry it off or take the blowdryer to it.
Please take precaution when doing this and I would unplug the fridge just to be on the safe side.
We paid $180.00 for someone to do this....if I would have known...lol. The technician did tell us we would need to replace the fan eventually but we haven't yet. I would say that it hums (loudly) every six months and we (my husband) have to repeat the steps above.
Hope this helps!
1helpful
Humming sound? motor or fan constantly running
Hi, It is the evaporator fan motor you are hearing. The motor is the only thing that shuts off when the door is open. The fan motor is located behond the rear panel inside the freezer sections.
I hope this helps you. Please let me know if I can assist you further.
Vic
1helpful
Ge eterna refrigerator loud humming
Thanks,
Bill
2answers
Whirlpool top freezer problem
Check for frost build-up behind back wall in freezer. If there is a heavy frost build-up, it's not defrosting. This will restrict airflow to refigerator section and can stop fan. If fan is stuck again and it's not because of frost, replace evaporator fan motor.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
