20 Most Recent Whirlpool ET1FHTXM Top Freezer Refrigerator Questions & Answers
2answers
Whirlpool Refrigerator not cooling properly
I would try replacing the defrost timer and cleaning the condenser fins.
4/19/2017 10:28:12 PM • Whirlpool... • Answered on Apr 19, 2017
2answers
My fridge does the open
Depending on which two numbers after the ET1FHTXM may make a difference. For example ET1FHTXM00 the only thing that may cause a beep or cut the refrigerator (that I know of) on or off would be=> Circuit Board or Timer 2213473 This is a ADC adaptive defrost control and when they go bad strange things happen.Click Here=>
Whirlpool ET1FHTXMQ01 parts manual.pdf
You can also find a Tech Sheet wiring diagram=> Here
Thanks, Sea Breeze
11/18/2015 5:13:55 AM • Whirlpool... • Answered on Nov 18, 2015
The fan stops when i open the fridge and it beeps about 10 times
The beeping is caused to notify you that temperatures are rising the=> 2304099 Defrost Control Board 1f08684d-5422-4036-a7fc-eecb98cc567e.jpgis possibly defective. Sometimes examining both sides of the defrost board will reveal burn marks or signs of heat damage but not always. Look inside the freezer to see if frost is building on the rear wall of the freezer. Here is a link to a photo of a freezer wall showing frost buildup HERE Here is a link to a parts manual T1FHTXMQ00 Parts Manual User Manual HEREOther parts that may cause the refrigerator to warm are the=> 2166124 Defrost Heater Assembly60e85f53-84e8-4735-abb3-10924736f690.jpgand the 2221677 Defrost Thermostat98b59da8-662c-4d74-8b25-e62874c702ef.jpgTesting the defrost heater and defrost thermostat are easy. I will be here should you have questions, Thanks Sea Breeze
4/10/2013 10:51:42 AM • Whirlpool... • Answered on Apr 10, 2013
How to change water filter
The water filter on this model is located on the bottom of the unit at the kickplate. You turn the unit counter clockwise to remove the filter.
3/13/2013 12:16:08 AM • Whirlpool... • Answered on Mar 13, 2013
My refrigerator is leaking water on the floor from the left side of the refrigerator
It sounds like you may have a frozen drain line in your freezer. If you have water under the crisper drawers in the ref section this would be a good indicator. If this is the case you could unplug the unit and leave both doors open for 24 hours to let your drain line thaw out. Hope this helps. MJ
12/1/2012 12:50:49 AM • Whirlpool... • Answered on Dec 01, 2012
2answers
My whirlpool model #ET1FHTXMQ01 keeps
We have had the same problem lately. We have called Whirlpool, looked all over the internet and asked several people but still cannot seem to find out why this happening. We constantly have to scrape the layer of ice off the bottom of the freezer and we also have to put a bowl in the back of our fridge where water continuously drips, if we don't, it floods our top shelves. I'm sorry I couldn't be much more help, but I wanted to let you know that you're not alone and that we have been experiencing the exact same issue. If I find out what's causing ours, I will be sure to come back and post it on here.
8/5/2012 2:33:15 AM • Whirlpool... • Answered on Aug 05, 2012
Annoying beeping of the Kenmore refrigerator!!!
I don't believe this model has an alarm in it. The beep you hear maybe the evaporator fan motor, also if there is an icemaker in the frig be sure it is turned off
11/27/2011 1:49:42 AM • Whirlpool... • Answered on Nov 27, 2011
I HAV A WHIRL. ET1FHTXMQ03
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
9/23/2011 11:45:06 PM • Whirlpool... • Answered on Sep 23, 2011
Kitchenaid KBFL25ETSS00 bottom freezer refrigerator
You mean the temps are getting warmer? Look inside the rear of your freezer and back wall and tell me if you see snow or a layir of frost building. If so pull everything and unplug and do a manual defrost a hair drier will speed things up.Sounds like we need to use the tech sheet here but Kitchenaid will not allow me to publish here. So Skater125 you need to click here and I will send it to you only, Thanks, Sea Breeze
9/17/2011 5:08:12 AM • Whirlpool... • Answered on Sep 17, 2011
The refrigerator compartment is not
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
9/16/2011 12:16:53 AM • Whirlpool... • Answered on Sep 16, 2011
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
103 questions posted
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
refrigerator water running down from
  • Refrigerators
