Method 2 of 3: Scan for Code
Use the remote to scan your device for the proper code. If the direct-entry method does not work, or your device is not listed in the back of the manual or online, you can try this procedure to find your device's code.
Turn on your remote device. Use either the device's power-on button, or use its remote control to turn it on.
Press and hold the mode button for the target device. Hold the button down for about 3 seconds, then release it. It should now be flashing.
Press the remote's power button. Note: use the generic power button, not the TV power buI need the remote codes to make my proscan tv work - 670px-program-a-dish-network-remote-step-10-version-2.jpgw.com/Image:Program-a-Dish-Network-Remote-Step-10-Version-2.jpg"> 5
Press the Up or Down arrow button until the device turns off. You will have to do this repeatedly to scan through all codes.
Lock in theI need the remote codes to make my proscan tv work - 670px-program-a-dish-network-remote-step-12-version-2.jpgs the Pound sign (#) to store that code in the remote.
Test the connection. Turn on the device with the power button, then test the other buttons such as Play, FasI need the remote codes to make my proscan tv work - 670px-program-a-dish-network-remote-step-13-version-2.jpgepeat the process again until you find a code that does. Method 3 of 3: By Menu
Select Settings. Locate and select the Remote Control button.
Select the device you want to learn. From the buttonsI need the remote codes to make my proscan tv work - 670px-program-a-dish-network-remote-step-17-version-2.jpgss="h_mi"> 4
Select the Lookup Code button:
SI need the remote codes to make my proscan tv work - 670px-program-a-dish-network-remote-step-18-version-2.jpgthe Next button:
Enter your model number in the search field. You can enter all, or part of the number.
SOURCE: Emerson tv remote code
I have ask some help from our friends and they also have problems regarding this type of TV... But try this one
Quotes from friends:
1. "The universal remote that came with my Motorola HD cable box worked fine"
2. chat sessions
3. Chat session find jcut92
My quote:
Ask the vendor for a code, if they don't give you return the TV , it lacks technical support... Believe me or else face more problems in the days to come.
I'm sorry, there's lo luck... Fixya me instead...
SOURCE: Remote code for Emerson SLC195EM82 TV
Here is a list of remote codes for Emerson TV: 004 009 014 023 024 025 026 027 030 032 033 034 035 036 037 038 039 040 041 042 043 045 046 049 053 116 135 147 177 179
Give them each a try (a pain I know) and please rate me if they work!
Take Care,
-WN
SOURCE: remote code for dish network remote to control olevia tvs
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Lone99star. Please rate this solution.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: codes for remote
I only have a solution for the directv remote codes use the LG TV code 10056.
SOURCE: remote code access
Hi, I tried 720 and it worked hold tv button until all buttons blink enter 720, #, big red power button and it should work.
good luck
