20 Most Recent Sanyo 42 in. LCD TV Questions & Answers
I had to call Sanyo on this same problem, and I just wanted to help you out on this. When you turn on the the TV and it asks for home or store, chose home then do the channel scan. After the channel scan completes, switch to your tv source, hdmi1, then turn off the tv and back on and it should just go straight back to hdmi1. Let me Know if this works!
Sanyo 42 in.... | Answered on Feb 16, 2019
Hi, you have not specified if your tv is still conventional tb that uses crt, or lcd
Sanyo 42 in.... | Answered on Jun 25, 2017
Only for a little suggestion even when it has nothing to do with this to know ? https://www.youtube.com/watch?v=t36YT7-5GTY but have you test those kind of fcc flatsheets by manipulating like for example pushing on it with a peace of towel on those sheets for a faultering test ? they can be dry out and come loose by direct sunlight or other cause by heating up over a time and it will become faultering.
Maybe it could be in cause of strange defects if you have service manual and all things measured do not use the new prints without heatsink it should allways on it if the same chipset is used if not modified , or you have bought a refurbished print because of the missing heatsink and metal cover?
Sanyo 42 in.... | Answered on Jun 05, 2017
I would just replace the TV, because any guess you make without the testing and equipment is just an expensive guess. New TV's are cheap by comparison. I have had a lot of TV'ds and the best do far is my Vizio 42 Inch LCD. 11 years old no issues.
Sanyo 42 in.... | Answered on May 20, 2017
Replace or have the powrer supply tested and eventually serviced.
Lightning strikes affect two types of boards in televisions - the power supply by means of entering through the AC line and main boards by means of entering from the external signal sources. External antennas are worst and can totally toast the main board whereas a signal entering through HDMI cable from another device is less likely to be affected by a power surge.
So naturally you start your quest with the power board , which is the usual suspect.
As of right now I do not believe we have an announced service for the power supply board of Sanyo LCD-24K50, but if you do not have any other options you can always try and send the power board for examination/repair through
http://www.coppelltvrepair.com/newservice.
Sanyo 42 in.... | Answered on Dec 27, 2016
Please know that VGA is an analog signal and HDMI is digital so it is impossible to go from one to the other without a converter. If you need to convert any VGA or component signal into a digital high definition HDMI signal up to 720p resolution, this conversion box will do the job perfectly. The only additional thing that you need to get besides this converter is an HDMI cable of the appropriate length.http://sewelldirect.com/Component-VGA-to-HDMI-Scaler-720p.asp Hope this Helps you!
Sanyo 42 in.... | Answered on Nov 20, 2016
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Sanyo 42 in.... | Answered on Aug 25, 2016
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Sanyo 42 in.... | Answered on Jul 22, 2016
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sanyo 42 in.... | Answered on Jun 14, 2016
If that is a plasma - and it sounds like it is - it probably needs a new upper buffer board or, better yet, both buffer boards replaced.
Sanyo 42 in.... | Answered on Jun 06, 2016
Was the TV on a surge protector? If not it likely the main circuit board is shorted out. Contact the local power provider and try submitting a claim for damage.
Sanyo 42 in.... | Answered on May 10, 2016
Check on the power connection cables through from the sanyo TV to the current outlets. make connection firmer to grip on for suply flow. Power on TV once more shoudl have some positive effect than as before
Sanyo 42 in.... | Answered on May 04, 2016
think u have menu on control unit turn sound back on some how it has been turned off
Sanyo 42 in.... | Answered on Apr 29, 2016
Many TVs require a remote control to access any function other than Vol+/-,Ch +/-
Sanyo 42 in.... | Answered on Apr 23, 2016
with either AV cables or an HDMI cable
Sanyo 42 in.... | Answered on Feb 24, 2016
489 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
total control universal remote urc
  • Televison & Video
