20 Most Recent Sylvania LC420SS8 LCD TV Questions & Answers
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Sylvania... | Answered on May 11, 2017
Hi Juan,
the resistor values you want are:
R52
RES METALIZED FILM T 1/4W F 3.92k?
R524
CARBON RES. 1/4W J 10k?
The complete Service Manual is available as a .pdf Here:
Sylvania LC420SS8 LCD TV Service Manual
Its free to view, but you'll have to agree to a free 14 day trial membership to download it. Hope this helps you,
Sylvania... | Answered on Jan 22, 2016
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sylvania... | Answered on May 26, 2015
usually with screws provided
Sylvania... | Answered on Mar 15, 2015
The thread size is standard, just a metric standard. To attach the Sylvania LCD427SSX to the wall mount bracket you'll need (4) metric 8mm machine screws with a 1.25mm pitch. You'll find them at your favorite neighborhood hardware store with the designation M8 1.25x40mm. (40mm long...the 30mm would be to short)
Sylvania... | Answered on Sep 25, 2014
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sylvania... | Answered on Sep 22, 2014
0029,0026,0039,0035,0033.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sylvania... | Answered on Aug 25, 2014
Try reprogramming the channels.
www.aaatvservice.com
Sylvania... | Answered on Aug 16, 2014
Check battery contacts, make sure they are clean or change batteries.
Jurgen
Sylvania... | Answered on May 31, 2014
Connected to what source?
Sylvania... | Answered on Apr 04, 2014
Main power supply regulator board is faulty. Replace it as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Sylvania... | Answered on Mar 24, 2014
In other words, the set is dead. Check and replace its main power regulator [SMPS], first. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
In my area, Comcast has blocked all free watchable basic channels. You now need a very small but special box to receive those. If it's a conventional cable box, you might have to call them to send a signal to reset it.
Sylvania... | Answered on Feb 15, 2014
Sylvania LC420SS8 LCD TV Logo
161 questions posted
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
no stanby light
  • Televison & Video
