SOURCE: Asked to repair a McCulloch wipper snipper model
the primer bulb has the valves in it ,check the in line fuel filter.take outlet off primerbulb,should pump thru from tank,thru the primerbulb
SOURCE: my stil wipper snipper starts and runs but only on
Most Stihl's are the same...Sounds like you need to adjust your mixture screws on the carby. you will need a small flat blade screwdriver (usually these are supplied with the wipper snipper from new and they have a little arrow on the top), H is for the High speed mixture screw, L is for the Low speed mixture screw. Turn the screws clockwise in until they seat (do NOT tighten!!) then turn them anti-clockwise the recommended amounts of turn on the cover around the holes. Careful not to lean the mixture out too much, but if it is the newer type they have a restictor on the High Speed that stops it at 3/4 of a turn. start it up and hopefully it will fix your problem, if not you will have to take it to a professional. Further info majority of STIHL high and low mixture setting are fine tuned via the respective rev settings , you'll have find out the particular setting from your STIHL dealer(sorry)
SOURCE: sabre victa whiper snipper does not cut the edges
shaft connection at the tip or top have become disengaged
SOURCE: how to set air fuel 323l wipper snipper runs for 2
Here are 2 links for adjusting the two popular brands of diaphragm carburetors:
http://www.zamacarb.com/tipspage.html
http://tech.flygsw.org/walbro_tuneup.htm
SOURCE: Hi, I have a Victa Tornado Plus Whipper Snipper
Hi and welcome to FixYa, I am Kelly. I know this is a 26 cc petrol engine on your trimmer but do not know if it is a 2 or 4 stroke engine. If you are in AU then it would be a 2 stroke. There are a few things that can cause this.
If you engine has a primer bulb.... Hold it depressed hard while trying to increase engine speed. What your trying to do by doing this is prevent air introduction via the primer bulb if it has a pin hole in it. If you can get normal speeds bu holding the primer bulb depressed HARD the primer bulb has a pin hole in it and must be replaced.
Also look inside the fuel tank at the fuel collection tube end. Usually there is a screen inside the tank. Some times the screen becomes coated with gunk and it has to be removed from inside the tank for cleaning.
If your carb has a fuel shut off on the side of it... unbolt the fuel manifold and pull the bolt out of the manifold. Models with this type of fuel shut off have a screen inside the manifold that has to be pushed out of the manifold and cleaned.
If after checking all of the above you still have the problem then it is time to remove the "L" fuel mixture screw on the side of the carb. BEFORE removal... rotate the screw clockwise counting turns until it JUST barely closes. Do not turn it tightly closed as the end of the mixture screw needle will break off inside the carb and you will have to replace the carb.
Then rotate the mixture screw ccw and remove it. Spray carb cleaner into the mixture screw hole to remove any debris.
IF your carb only has an "H" screw perform the same procedure above but for sure clean both the "H" and "L" mixture holes with carb cleaner. Wipe off the needles too.
Install both screws CW until closed and then reverse the number of turns CCW you counted before removal for EACH of the 2 mixture screws.
Make sure the FOAM Air Filter is NOT clogged with debris. Clean as necessary.
Start the engine and let it warm up briefly. Attempt to increase speed slowly to full speed. If the engine hesitates open the "L" mixture screw less than 1/8 th turn and try again. You should note a change in performance after rotating the "L" Mixture screw ccw. Begin rapidly throttling up the engine after EACH adjustment until the engine no longer hesitates or tries to stall upon acceleration from idle.
RUN the engine at TOP SPEED. Adjust the "H" Mixture screw until you get maximum engine rpm. You will NOT hurt the engine but it must run at MAX speed smoothly.
CHECK acceleration from idle to MAX again. re-adjust "L" mixture if necessary.
One last thing to check is make sure the gas cap is vented. Without a vented gas cap the engine will run briefly then perfromace will degrade substantially. Many times on trimmers I see people place plastic over the fuel tank fill hole and install a damaged cap. Replacing the cap has fixed many many trimmers with tank vent problems due to a bad fuel cap!
This should get you going again. If you need any more assistance or you still have the problem after performing the aboe please respond here with any updates.
Thanks for choosing FixYa,
Kelly
