I can hear the caller and the dial tone but they cannot hear me.
There is a mute button, but usually this needs to be pressed after the call is connected. Your issue may be that your extension is not set up for handsfree in the capability programming of your set.
Have you tried another handset or especially another handset cord? Those problems are usually poor connections at the small modular connectors for the handset.
SOURCE: NorStar T7316E Corded Phone Problem - mailbox locked
You will need to dial into the system admin of the voicemail
Feature 983
the password is dependant on how many digits your extensions use. 1020000 for 3 digit and 10020000 for 4 digit, 120000 for 2 digit.
go through the screens
Mailboxes, modify, scroll to password and press change.
Will reset to 0000.
SOURCE: Norstar m7310 phone
Go to 'Setup / Feature' -> look for the menu item with option as Tone OR pulse...this is where u have to change :)
SOURCE: Norstar T7316e
chang the call log options to none on the specific phone you want it to stop on. or you can go to feature settings and change the call log options to 0 system wide..
SOURCE: Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
SOURCE: T7316e Nortel Meridian Norstar Telephone MANUAL
Not too sure what type of manual you are looking for, but here is a useful link to have for a Norstar system information.
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
