Turns on but no sound out
Step 1:
Check the setting of LOCAL CONTROL in GLOBAL mode.
Go to GLOBAL mode page 1 (Figure 1-2):
Move the cursor from the MASTER TUNE to LOCAL CONTROL. Setting LocalControl should be in the ON position.
When the setting is OFF,set it to ON (use dial TEMPO / VALUE or DOWN / UP button).
Go back to ARR or PROG mode,and play the key to check audio.
Step 2:
If in step 1, the sound still does not exist, then it is a hardware problems, and the possibilities are :
Figure 3, the section in red shading is a block may be damaged.
Figure 4 is a scheme.korg i3 keyboard no sound out - korg-i3-keyboard-no-sound-out-fuxmm42irvf2p03kxwfdv02c-5-6.jpg42irvf2p03kxwfdv02c-5-6.jpg" alt="korg-i3-keyboard-no-sound-out-fuxmm42irvf2p03kxwfdv02c-5-6.jpg" class="h_mi" />Parts that might be damaged in case of no-audio are:
IC 2,4,5 (4570), IC9 (78L05), IC6 (PCM69AU), IC 3 (5216).
Check also the transistors Q1-Q7 (This is the MUTE transistor, and this is most often the cause in case of no-audio).
If you can not fix it by yourself, then leave it to the experts.
SOURCE: Korg TR88 splitting the keyboard.
Read the manual if you've got it. If not get in touch with Korg.com and they should be able to tell you and you might get a manual download.
Good Luck
