Have you check connection wireS, connector contact , finally the control switch ?
Using contact cleaner to clear dirt at connector, checking connector pins as we'll.
the wireS maybe broken ..
FIRST MAKE SURE YOU DID NOT LOCK THE WINDOW, BY RELEASING THE BUTTON, THEN REMOVE DOOR PANEL ON PASSENGER SIDE , UNPLUG WINDOW MOTOR, AND TEST FOR POWER AND GROUND AS SOME ONE PUTS THE WINDOW DOWN FROM BOTH SWITCHES, IF POWER AND GROUND IS THERE REPLACE MOTOR, IF NO POWER THERE CHECK SWITCH, POSIBLE BAD SWITCH, BUT IF YOU SUSPECT WIRING , CHECK THE DOOR JUMB ON DRIVERS SIDE, INSIDE THE RUBBER BOOT MAY BE ONE OR MORE BROKEN WIRES , REPAIR THEM. NORMAL
you bled doors are not working, could be a broken vacuum line, vacuum line fell off or one of your actuators is not working, you would have to look under your. dashboard to check these, see if you can move your actuator
Needs driverside door regulator if you can see the glass grab the glass one hand on each side pull up if it does not go up all the way press up button on switch to help it up tape glass to keep in place till you replace it part is cheep. if glass fell in you have to pull door panel push glass up and tape
Have you had your windows down in a rain storm, ecspecially the driverside,if so you may need to replace the window controls on the driverside.One fuse should operate all window motors.if the fuse is good then it may be the motor on the passenger side went out and may just need replaced.
Good Evening, most cases it is a faulty window regulator, however the usual suspect (a non-replaceable part) is the little ball cups that hold the track under the window to the regulator itself. They are really not that expensive and most places like autozone carry these in stock. Hope that helps. Thanks, Joey
